    Update notification not working
    7 Posts 3 Posters 5.0k Views 3 Watching
    • tosti007T Offline
      tosti007 Module Developer
      I am not sure if I am the only one so I thought it would be better to open a topic here instead.
      The problem is with the default updatenotification. After doing quite some testing I found out that there is quite a big problem.
      In the node_helper.js function configureModules there is a loop that goes through all the modules that aren’t default ones. In this loop there is a variable made named git and it’s function getRemotes is called with some kind of callback function. The problem here is that that callback function is never called. This results in the simpleGits array to be empty and then the preformFetch doesn’t have much to work with.
      Lastly the preformFetch isn’t declared properly inside the object. It currently is preformFetch() {//whatever}, and should be preformFetch: function () {//whatever}.
      Is anyone able to reproduce this problem or is it just me (windows 10)?
      TLDR; updatenotification > node_helper.js > lines 33-44 broken, someone fix?
      If there is anything don't hesitate to contact me!
      ProfileSwitcher, TouchNotifications
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @tosti007
        @tosti007 if you want and have the time you can compare it with my mobile module, this has pretty much the same functionality and works for me. Maybe you’ll find the issue.
        tosti007T 1 Reply Last reply Reply Quote 0
        • tosti007T Offline
          tosti007 Module Developer @strawberry 3.141
          @strawberry-3.141 looked through your post and github page, to which module are you referring? (link? :) I had struggles finding it)
            @tosti007 it starts here https://github.com/fewieden/MMM-Mobile/blob/c0739ceb43f303af02886abcd560033acbbba4c4/node_helper.js#L67
            tosti007T N 2 Replies Last reply Reply Quote 0
            • tosti007T Offline
              @strawberry-3.141 thank you! I will check it out :)
              • N Offline
                nobita @strawberry 3.141
                @strawberry-3.141 said in Update notification not working:
                what is different MMM-Mobile VS phone_notification
                • tosti007T Offline
                  tosti007 Module Developer @nobita
                  @nobita MMM-Mobile is for his app he is making
