    My 1st MagicMirror2
    21 Posts 10 Posters 23.9k Views 10 Watching
      sithlordhood
      Here is my first MagicMirror:
      alt text alt text
      alt text
      Rear View:
      alt text
      (the green tape covers the very sensitive motion sensor, I went for this one in the end: http://tinyurl.com/jdkb9fw)
      The frame was made from Pine, stained with varnish.
      Vent holes in the top and bottom, small fan in the top to aid airflow.
      The bottom holes also allow for a few Status LED’s (Monitor power / PIR trigger) and also allow access to a potentiometer to adjust the sensitivity of the PIR.
      I also extended 2x USB ports from the Pi to the bottom of the mirror so that I can plug in a keyboard/mouse for maintenance purposes whilst the mirror is still mounted on the wall.
      If there is no PIR trigger for a few minutes the Pi disables HDMI output, putting the monitor into Standby. Detection to monitor back on is 4 seconds, since the sensor is very sensitive I never see the monitor powering back up.
      1 Reply Last reply Reply Quote 4
      • CatoC Offline
        Cato Module Developer
        Nice!
        You say that the motion sensor is very sensitive. Do you get any false positives or is it sometimes it doesn’t trigger when it should?
        I like the idea of an USB extension! Why didn’t I think of that… 😉
        S cowboysdudeC 2 Replies Last reply Reply Quote 1
        • P Offline
          plumcraft
          Nice, really clean dashboard
            djdwayneanthony
            I love this! What a great dashboard! The colours, the layout, the features/modules you are using! I really like the “Hood Family mobile phones” module! What a brilliant way of keeping tabs on who’s in and who’s out! Commute to different destinations, it’s great!
            I’m sure none of it is overly difficult to an experienced wizard, me however, it’s like learning Russian and Cantonese at the same time, my mind is melting! haha
            Would you be willing to share your config.js.sample, .css and any other relevant info (probably with instructions for the newbies like me) and for others to clone parts of your fantastic design?
            S 2 Replies Last reply Reply Quote 1
              sithlordhood @Cato
              @Cato It always triggers when it should. The sensor is quite powerful though in that it will work through stud walls… even with the sensitivity at the lowest setting! Not really a problem as the Mirror is downstairs in the house so when people are in the mirror is ‘on’ but come bed time and when the house is unoccupied the mirror turns off.
                sithlordhood @djdwayneanthony
                @djdwayneanthony Sure,
                Here is my config.js:
                /* Magic Mirror Config fILE
                • By Michael Teeuw http://michaelteeuw.nl
                • MIT Licensed.
                var config = {
                port: 8080,
                language: 'en',
                timeFormat: 24,
                units: 'metric',
                		module: 'alert',
                			welcome_message: 'Welcome, Magic Mirror boot-up successful!',
                		module: 'MMM-Remote-Control',
                //uncomment for url position: ‘top_left’,
                //uncomment {
                //for module: ‘MMM-Snow’,
                //s position: ‘fullscreen_above’,
                //n config: {
                //o flakeCount: 50,
                //w }
                module: ‘clock’,
                module: ‘calendar’,
                header: ‘The Hoods Calendar’,
                maximumEntries: 25,
                maximumNumberOfDays: 365,
                maxTitleLength: 25,
                animationSpeed: 0,
                fadePoint: 1,
                timeFormat: ‘absolute’,
                urgency: 7,
                symbol: ‘calendar’,
                url: ‘GOOGLE CALENDAR URL’
                module: ‘currentweather’,
                position: ‘top_right’,
                locationID: ‘2649692’, //ID from http://www.openweathermap.org
                appid: ‘API KEY’,
                module: ‘weatherforecast’,
                header: ‘Weather Forecast’,
                fadePoint: 1,
                appid: ‘API KEY’,
                showRainAmount: true,
                module: ‘MMM-NetworkScanner’,
                header: ‘Hood Family Mobile Phones’,
                devices: [
                { macAddress: “MAC1”, name: " Internet Router", icon: “wifi”},
                { macAddress: “MAC2”, name: “Simon”, icon: “mobile”},
                { macAddress: “MAC3”, name: “Emma”, icon: “mobile”},
                { macAddress: “MAC4”, name: “Jacob”, icon: “mobile”},
                { macAddress: “MAC5”, name: “Rhiannon”, icon: “mobile”},
                showUnknown: false,
                showOffline: true,
                keepAlive: 240,
                updateInterval: 10,
                module: ‘calendar_monthly’,
                fadeSpeed: 2,
                showHeader: ‘true’,
                cssStyle: ‘custom’, //block, clean, slate or custom
                updateDelay: 5,
                module: ‘newsfeed’,
                position: ‘bottom_bar’,
                showDescription: true,
                feeds: [
                title: “BBC News”,
                url: “http://feeds.bbci.co.uk/news/rss.xml?edition=uk”
                showSourceTitle: true,
                showPublishDate: true
                module: ‘MMM-Traffic’,
                classes: ‘dimmed medium’,
                api_key: ‘API KEY’,
                mode: ‘driving’,
                origin: ‘ORIGIN’,
                destination: ‘DESTINATION’,
                // arrival_time: ‘0730’, //optional, but needs to be in 24 hour time if used.
                route_name: ‘Simon - Home to Work’,
                changeColor: ‘true’,
                showGreen: ‘true’,
                limitYellow: 15, //Greater than 15% of journey time due to traffic
                limitRed: 30, //Greater than 30% of journey time due to traffic
                traffic_model: ‘pessimistic’,
                interval: 120000 //2 minutes
                classes: ‘dimmed medium’, //optional, default is ‘bright medium’, only applies to commute info not r$
                api_key: ‘API KEY’,
                mode: ‘driving’,
                origin: ‘ORIGIN’,
                route_name: ‘Emma - Home to Nursery’,
                showGreen: ‘true’,
                api_key: ‘API KEY’,
                mode: ‘driving’,
                origin: ‘ORIGIN’,
                route_name: ‘Home to Nana & Grandad Hoods’,
                showGreen: ‘true’,
                module: ‘mmm-systemtemperature’,
                classes: ‘small dimmed’,
                prependString: 'CPU Temp: ',
                updateInterval: 5000,
                animationSpeed: 0,
                module: ‘updatenotification’,
                if (typeof module !== ‘undefined’) {module.exports = config;}
                bolded text
                I have removed api keys, destinations, etc so anything in ITALICS you would require adding your own variable here as described in the modules.
                The Modules I used are:
                alert (default module)
                MMM-Remote-Control
                MMM-Snow (I only configure this ON during the holiday period!)
                clock (default module)
                calendar (default module)
                currentweather (default module)
                weatherforecast (default module)
                MMM-NetworkScanner
                calendar_monthly
                newsfeed (default module)
                MMM-Traffic (used three times, for different commutes)
                updatenotification (default module)
                • brobergB Offline
                  broberg Project Sponsor
                  You could remove the margins of the MM body, that way you would utilize more of the screen itself, since you have more mirror on the sides of the monitor :)
                  S schlachtkreuzer6S 4 Replies Last reply Reply Quote 0
                    sithlordhood @broberg
                    @broberg I will look into this - will give me a little more room. Cheers!
                      @djdwayneanthony Also here is my custom.css - it is only colour changes for the Weather forecast and not my work - copied from someone else’s post here…
                      • Magic Mirror *
                      • Custom CSS *
                      • By Michael Teeuw http://michaelteeuw.nl *
                      • MIT Licensed. *
                      • Add any custom CSS below. *
                      • Changes to this files will be ignored by GIT. *
                      body {
                      .dimmed {
                      color: #666;
                      .normal {
                      color: #999’
                      .bright {
                      color: #fff;
                      .brightb {
                      color: #55acee;
                      .currentweather .wi-sunrise {
                      color: #ffd700;
                      .currentweather .wi-sunset {
                      color: #ffa500;
                      .currentweather .wi-day-sunny {
                      color: #ffff00;
                      .currentweather .wi-night-showers {
                      color: #55acee;
                      .currentweather .wi-degrees {
                      color: #415;
                      .currentweather .wi-rain {
                      color: #55acee;
                      .currentweather .wi-showers {
                      color: #55acee;
                      color: #55acee;
                      .currentweather .wi-night-alt-cloudy-windy {
                      color: #aaa;
                      .currentweather .wi-night-cloudy {
                      color: #aaa;
                      .currentweather .wi-cloudy {
                      color: #aaa;
                      .currentweather .wi-day-cloudy {
                      color: #aaa;
                      color: #aaa;
                      .currentweather .wi-cloudy-windy {
                      color: #aaa;
                      color: #55acee;
                      .currentweather .wi-thunderstorm {
                      color: #ff00ff;
                      .currentweather .wi-snow {
                      color: #fff;
                      .currentweather .wi-fog {
                      color: #999;
                      .currentweather .wi-night-clear {
                      color: #fff;
                      .currentweather .wi-night-rain {
                      color: #55acee;
                      .currentweather .wi-night-thunderstorm {
                      color: #ff00ff;
                      .currentweather .wi-night-snow {
                      color: #fff;
                      .weatherforecast .wi-sunrise {
                      color: #ffd700;
                      .weatherforecast .wi-sunset {
                      color: #ffa500;
                      .weatherforecast .wi-day-sunny {
                      color: #ffff00;
                      .weatherforecast .wi-night-showers {
                      color: #55acee;
                      .weatherforecast .wi-degrees {
                      color: #415;
                      .weatherforecast .wi-rain {
                      color: #55acee;
                      .weatherforecast .wi-showers {
                      color: #55acee;
                      color: #55acee;
                      .weatherforecast .wi-night-alt-cloudy-windy {
                      color: #aaa;
                      .weatherforecast .wi-night-cloudy {
                      color: #aaa;
                      .weatherforecast .wi-cloudy {
                      color: #aaa;
                      .weatherforecast .wi-day-cloudy {
                      color: #aaa;
                      color: #aaa;
                      .weatherforecast .wi-cloudy-windy {
                      color: #aaa;
                      color: #55acee;
                      .weatherforecast .wi-thunderstorm {
                      color: #ff00ff;
                      .weatherforecast .wi-snow {
                      color: #fff;
                      .weatherforecast .wi-fog {
                      color: #999;
                      .weatherforecast .wi-night-clear {
                      color: #fff;
                      .weatherforecast .wi-night-rain {
                      color: #55acee;
                      .weatherforecast .wi-night-thunderstorm {
                      color: #ff00ff;
                      color: #fff;
                        djdwayneanthony
                        Legend! Will play about with this tomorrow! Thank you, and once again, well done!
                        • 1 / 3
