    Personalize Compliments
    6 Posts 3 Posters 3.7k Views 3 Watching
      reaper81
      Hi, I would like to personalize the Compliments-Module with Paviros Facial Recognition-Module. Is there any posibility to use different Comliments for different users?
      • yawnsY Offline
        yawns Moderator
        I guess if you use https://github.com/tosti007/MMM-ProfileSwitcher with FacialRecognition you can use different compliments. However this is untested.
        tosti007T 1 Reply Last reply Reply Quote 0
        • tosti007T Offline
          tosti007 Module Developer @yawns
          @yawns @reaper81 my module only shows a message when you actually change user. You can customise this message (and set multiple) any way you want, but it’s only shown once as an notification
          If there is anything don't hesitate to contact me!
          ProfileSwitcher, TouchNotifications
          • tosti007T Offline
            The way I understand what you want is that you want to use the compliment module as it is, but just like with the different times or weather you want to have some for a specific person?
            I think that changing a default module for two other (non default) modules that not everybody is going to use is the best of ideas and is something that the people who are more involved in modifying the framework are too keen on doing so.
            It would be possible to make a stand alone module, which would be a copy with some additional features.
            @yawns do you have any other solutions? Since either of these two aren’t the best imo.
            • yawnsY Offline
              yawns Moderator
              My understanding of your module was that you can add modules and assign class names so it is loaded only when the named user is logged in.
              My approach was to add the compliments module several times, but with different compliment.json files
              • tosti007T Offline
                @yawns Ohh yes ofcourse that would work aswell and is way easier!
                @reaper81 This would be the easiest solution
