    MMM-Domoticz-ext: interact with Domoticz
    121 Posts 14 Posters 97.1k Views 16 Watching
    • G Offline
      goedh452 @steps39
      @steps39
      Which gauges are you trying to display, utilities or weather? I tested the utilities with energy monitors that are collected to Domoticz with a P1 USB cable. You too?
      The module should autodetect the type and disregard types it doesn’t know. Maybe this mechanism isn’t working as it should be for the gauges. I’ll look into this.
      Regarding the git-error: I added the package.json for the dependencies. I’m not very experienced with GitHub and more of a hobby programmer. I guess there is something wrong with the package.json. Any input is welcome!
      steps39S 1 Reply Last reply Reply Quote 0
      • steps39S Offline
        steps39 @goedh452
        @goedh452 thanks, my skill is also amateur, but I now know that there is no gauge dependency missing.
        I have a whole range of energy values captured in my Domoticz - Owl current meter, Nibe heat pump, Solaredge PV panels, I guess none of them are the same type as your P1 USB cable (not something I use/have).
        I guess I would really want a flexible gauge that I can use with a number of my Domoticz captured values, so your Javascript is a great inspiration/start to create such gauges.
        I will fork your git and then if I actually create something it will hopefully add to your package. As a hobby not sure when I will get around it :-(.
        • G Offline
          goedh452 @steps39
          @steps39
          You could send me the json result of you sensors and I’ll see what I can do. The result is obtained via this URL:
          http://<IPADRESS_DOMOTICZ>:<PORT_DOMOTICZ>/json.htm?type=devices&rid=<IDX_DEVICE>
          • steps39S Offline
            steps39 @goedh452
            @goedh452 thank you very much, a couple of examples below.
            My Owl device measures watts, but each time I change the batteries it get a new idx, so I use a Lua script in Domoticz to capture the values and post-process before displaying as a Solar below:
               "ActTime" : 1617792992,
               "AstrTwilightEnd" : "22:07",
               "AstrTwilightStart" : "04:07",
               "CivTwilightEnd" : "20:30",
               "CivTwilightStart" : "05:44",
               "DayLength" : "13:31",
               "NautTwilightEnd" : "21:16",
               "NautTwilightStart" : "04:59",
               "ServerTime" : "2021-04-07 11:56:32",
               "SunAtSouth" : "13:07",
               "Sunrise" : "06:21",
               "Sunset" : "19:53",
               "app_version" : "4.10717",
               "result" : [
                     "AddjMulti" : 1.0,
                     "AddjMulti2" : 1.0,
                     "AddjValue" : 0.0,
                     "AddjValue2" : 0.0,
                     "BatteryLevel" : 255,
                     "CounterToday" : "6.210 kWh",
                     "CustomImage" : 0,
                     "Data" : "39023.996 kWh",
                     "Description" : "",
                     "EnergyMeterMode" : "",
                     "Favorite" : 1,
                     "HardwareID" : 3,
                     "HardwareName" : "DUMMY",
                     "HardwareType" : "Dummy (Does nothing, use for virtual switches only)",
                     "HardwareTypeVal" : 15,
                     "HaveTimeout" : false,
                     "ID" : "00014179",
                     "LastUpdate" : "2021-04-07 11:56:30",
                     "Name" : "Solar",
                     "Notifications" : "false",
                     "PlanID" : "0",
                     "PlanIDs" : [ 0 ],
                     "Protected" : false,
                     "ShowNotifications" : true,
                     "SignalLevel" : "-",
                     "SubType" : "kWh",
                     "SwitchTypeVal" : 0,
                     "Timers" : "false",
                     "Type" : "General",
                     "TypeImg" : "current",
                     "Unit" : 1,
                     "Usage" : "1409.4 Watt",
                     "Used" : 1,
                     "XOffset" : "0",
                     "YOffset" : "0",
                     "idx" : "298"
               "status" : "OK",
               "title" : "Devices"
            The raw Owl device returns 3 power readings, one from each current clamp:
               "ActTime" : 1617793340,
               "ServerTime" : "2021-04-07 12:02:20",
               "Sunset" : "19:53",
               "result" : [
                     "AddjMulti" : 1.0,
                     "AddjMulti2" : 1.0,
                     "AddjValue" : 0.0,
                     "AddjValue2" : 0.0,
                     "BatteryLevel" : 100,
                     "CustomImage" : 0,
                     "Data" : "506 Watt, 138 Watt, 1863 Watt",
                     "Description" : "",
                     "Favorite" : 0,
                     "HardwareID" : 1,
                     "HardwareName" : "RFXCOM",
                     "HardwareType" : "RFXCOM - RFXtrx433 USB 433.92MHz Transceiver",
                     "HardwareTypeVal" : 1,
                     "ID" : "6700",
                     "LastUpdate" : "2021-04-07 12:02:12",
                     "Name" : "Owl",
                     "Notifications" : "true",
                     "PlanID" : "0",
                     "PlanIDs" : [ 0 ],
                     "SignalLevel" : 7,
                     "SubType" : "CM113, Electrisave",
                     "Timers" : "false",
                     "Type" : "Current",
                     "Unit" : 0,
                     "Used" : 1,
                     "XOffset" : "0",
                     "YOffset" : "0",
                     "displaytype" : 1,
                     "idx" : "1286"
               "status" : "OK",
               "title" : "Devices"
            G 2 Replies Last reply Reply Quote 0
            • G Offline
              goedh452 @steps39
              @steps39
              Thanks! I’ll look into it. A quick glance indicates that the subtype of the solar device is ‘kWh’ and the module scans for a subtype ‘Energy’. This is easy to modify in the code. The Owl device is a bit more complicated since it has the data-attribute, but does not split this into 3 separate attributes.
              I’ll let you know if I’ve something for you to test!
              • G Offline
                goedh452 @steps39
                @steps39
                Could you please pull the latest code from GitHub and check if the Solar device works now?
                • steps39S Offline
                  steps39 @goedh452
                  @goedh452 thanks, I had a go but it just display “Loading…” under the DOMOTICZ module label.
                  I have simplified my config.js to just have this in the Domoticz module:
                                    module: "MMM-Domoticz-ext",
                                    header: "Domoticz",
                                    position: "top_center",
                                      apiBase: "192.168.89.174",
                                      apiPort: "8080",
                                      updateInterval: 10,
                                      displayType: "all",
                                      rooms: [
                                        { idx: "3" }
                                      utilities: {
                                        devices: [ "301" ],
                                        utilityLabel: "Solar",
                                        counterTodayLabel: "Vandaag",
                                        gaugeWidth: 200,
                                        gaugeEnergyMinValue: -3000,
                                        gaugeEnergyMaxValue: 3000,
                                        gaugeEnergyAppendText: "Watt",
                                        useColors: true,
                  • N Offline
                    najtram
                    Would it be possible to hide the sub headers?
                    The Utilities title doesn’t fit my minimal approach. The titles of the gauges tells enough (for me)
                    • N Offline
                      najtram @najtram
                      @najtram
                      I tried:
                      p.title.bright.domoCenterCell {
                        display: none;
                      hr.domoDivider {
                        display: none;
                      in custom.css… that worked. → Solved!
                      • G Offline
                        goedh452 @najtram
                        @najtram Ow great! I was thinking of making it an option, but if this solves it for you that’s fine of course.
                        • 12
                        • 13
                        • 2 / 13
