    MMM-Domoticz-ext: interact with Domoticz
    121 Posts 14 Posters 122.6k Views 16 Watching
    • G
      goedh452 @najtram
      @najtram
      You should install it on the pi which runs Magic Mirror. I’ll add a package.json later. That is the right way to do it indeed.
      N 1 Reply Last reply
      • N
        najtram @goedh452
        @goedh452
        Thanks for both your support. I excecuted it in the MagicMirror directory. And it is working!!! This is really awesome!
        Thanks for the great module!
        steps39S 1 Reply Last reply
        • steps39S
          steps39 @najtram
          @goedh452 nice add-on thank you.
          I am able to get simple things to work ok, but can’t get gauges to display. I assume the communication with my Domoticz server is all working, as number of lights on etc. gets displayed and there are no errors in the log for devices not being found. If I use a non-existent device or wrong type of device, then the Domoticz module just displays Loading.
          Do I need another dependency for gauges?
          Also having done a git pull to install package.json this causes Magic Mirror to error, but all is fine if I remove package.json
          0|mm  |     at Module.require (internal/modules/cjs/loader.js:1032:19)
          0|mm  |     at require (internal/modules/cjs/helpers.js:72:18)
          0|mm  |     at loadModule (/home/pi/MagicMirror/js/app.js:126:19) {
          0|mm  |   path: '/home/pi/MagicMirror/modules/MMM-Domoticz-ext/package.json'
          0|mm  | }
          0|mm  | [05.04.2021 15:22.59.747] [ERROR]
          I also get a git error, I don’t know if this matters or not:
          0|mm  | [05.04.2021 15:36.09.261] [INFO]  Checking git for module: MMM-VoiceAssistant
          0|mm  | [05.04.2021 15:36.09.263] [INFO]  Checking git for module: MMM-Domoticz-ext
          0|mm  | [05.04.2021 15:36.10.881] [ERROR] Failed to fetch git data for MMM-Domoticz-ext: Error: block timeout reached
          0|mm  | [05.04.2021 15:36.11.972] [ERROR]
          Thanks, exciting package, a lot of options to make sense of along with the complexities of my Domoticz, having a heat pump there are lots of energies and temperatures that I would like to be able to monitor.
          G 1 Reply Last reply
          • G
            goedh452 @steps39
            @steps39
            Which gauges are you trying to display, utilities or weather? I tested the utilities with energy monitors that are collected to Domoticz with a P1 USB cable. You too?
            The module should autodetect the type and disregard types it doesn’t know. Maybe this mechanism isn’t working as it should be for the gauges. I’ll look into this.
            Regarding the git-error: I added the package.json for the dependencies. I’m not very experienced with GitHub and more of a hobby programmer. I guess there is something wrong with the package.json. Any input is welcome!
            • steps39S
              steps39 @goedh452
              @goedh452 thanks, my skill is also amateur, but I now know that there is no gauge dependency missing.
              I have a whole range of energy values captured in my Domoticz - Owl current meter, Nibe heat pump, Solaredge PV panels, I guess none of them are the same type as your P1 USB cable (not something I use/have).
              I guess I would really want a flexible gauge that I can use with a number of my Domoticz captured values, so your Javascript is a great inspiration/start to create such gauges.
              I will fork your git and then if I actually create something it will hopefully add to your package. As a hobby not sure when I will get around it :-(.
              • G
                goedh452 @steps39
                @steps39
                You could send me the json result of you sensors and I’ll see what I can do. The result is obtained via this URL:
                http://<IPADRESS_DOMOTICZ>:<PORT_DOMOTICZ>/json.htm?type=devices&rid=<IDX_DEVICE>
                • steps39S
                  steps39 @goedh452
                  @goedh452 thank you very much, a couple of examples below.
                  My Owl device measures watts, but each time I change the batteries it get a new idx, so I use a Lua script in Domoticz to capture the values and post-process before displaying as a Solar below:
                     "ActTime" : 1617792992,
                     "AstrTwilightEnd" : "22:07",
                     "AstrTwilightStart" : "04:07",
                     "CivTwilightEnd" : "20:30",
                     "CivTwilightStart" : "05:44",
                     "DayLength" : "13:31",
                     "NautTwilightEnd" : "21:16",
                     "NautTwilightStart" : "04:59",
                     "ServerTime" : "2021-04-07 11:56:32",
                     "SunAtSouth" : "13:07",
                     "Sunrise" : "06:21",
                     "Sunset" : "19:53",
                     "app_version" : "4.10717",
                     "result" : [
                           "AddjMulti" : 1.0,
                           "AddjMulti2" : 1.0,
                           "AddjValue" : 0.0,
                           "AddjValue2" : 0.0,
                           "BatteryLevel" : 255,
                           "CounterToday" : "6.210 kWh",
                           "CustomImage" : 0,
                           "Data" : "39023.996 kWh",
                           "Description" : "",
                           "EnergyMeterMode" : "",
                           "Favorite" : 1,
                           "HardwareID" : 3,
                           "HardwareName" : "DUMMY",
                           "HardwareType" : "Dummy (Does nothing, use for virtual switches only)",
                           "HardwareTypeVal" : 15,
                           "HaveTimeout" : false,
                           "ID" : "00014179",
                           "LastUpdate" : "2021-04-07 11:56:30",
                           "Name" : "Solar",
                           "Notifications" : "false",
                           "PlanID" : "0",
                           "PlanIDs" : [ 0 ],
                           "Protected" : false,
                           "ShowNotifications" : true,
                           "SignalLevel" : "-",
                           "SubType" : "kWh",
                           "SwitchTypeVal" : 0,
                           "Timers" : "false",
                           "Type" : "General",
                           "TypeImg" : "current",
                           "Unit" : 1,
                           "Usage" : "1409.4 Watt",
                           "Used" : 1,
                           "XOffset" : "0",
                           "YOffset" : "0",
                           "idx" : "298"
                     "status" : "OK",
                     "title" : "Devices"
                  The raw Owl device returns 3 power readings, one from each current clamp:
                     "ActTime" : 1617793340,
                     "ServerTime" : "2021-04-07 12:02:20",
                     "Sunset" : "19:53",
                     "result" : [
                           "AddjMulti" : 1.0,
                           "AddjMulti2" : 1.0,
                           "AddjValue" : 0.0,
                           "AddjValue2" : 0.0,
                           "BatteryLevel" : 100,
                           "CustomImage" : 0,
                           "Data" : "506 Watt, 138 Watt, 1863 Watt",
                           "Description" : "",
                           "Favorite" : 0,
                           "HardwareID" : 1,
                           "HardwareName" : "RFXCOM",
                           "HardwareType" : "RFXCOM - RFXtrx433 USB 433.92MHz Transceiver",
                           "HardwareTypeVal" : 1,
                           "ID" : "6700",
                           "LastUpdate" : "2021-04-07 12:02:12",
                           "Name" : "Owl",
                           "Notifications" : "true",
                           "PlanID" : "0",
                           "PlanIDs" : [ 0 ],
                           "SignalLevel" : 7,
                           "SubType" : "CM113, Electrisave",
                           "Timers" : "false",
                           "Type" : "Current",
                           "Unit" : 0,
                           "Used" : 1,
                           "XOffset" : "0",
                           "YOffset" : "0",
                           "displaytype" : 1,
                           "idx" : "1286"
                     "status" : "OK",
                     "title" : "Devices"
                  G 2 Replies Last reply
                  • G
                    goedh452 @steps39
                    @steps39
                    Thanks! I’ll look into it. A quick glance indicates that the subtype of the solar device is ‘kWh’ and the module scans for a subtype ‘Energy’. This is easy to modify in the code. The Owl device is a bit more complicated since it has the data-attribute, but does not split this into 3 separate attributes.
                    I’ll let you know if I’ve something for you to test!
                    • G
                      goedh452 @steps39
                      @steps39
                      Could you please pull the latest code from GitHub and check if the Solar device works now?
                      • steps39S
                        steps39 @goedh452
                        @goedh452 thanks, I had a go but it just display “Loading…” under the DOMOTICZ module label.
                        I have simplified my config.js to just have this in the Domoticz module:
                                          module: "MMM-Domoticz-ext",
                                          header: "Domoticz",
                                          position: "top_center",
                                            apiBase: "192.168.89.174",
                                            apiPort: "8080",
                                            updateInterval: 10,
                                            displayType: "all",
                                            rooms: [
                                              { idx: "3" }
                                            utilities: {
                                              devices: [ "301" ],
                                              utilityLabel: "Solar",
                                              counterTodayLabel: "Vandaag",
                                              gaugeWidth: 200,
                                              gaugeEnergyMinValue: -3000,
                                              gaugeEnergyMaxValue: 3000,
                                              gaugeEnergyAppendText: "Watt",
                                              useColors: true,
                        • N
                          najtram
                          Would it be possible to hide the sub headers?
                          The Utilities title doesn’t fit my minimal approach. The titles of the gauges tells enough (for me)
                          • N
                            najtram @najtram
                            @najtram
                            I tried:
                            p.title.bright.domoCenterCell {
                              display: none;
                            hr.domoDivider {
                              display: none;
                            in custom.css… that worked. → Solved!
                            • G
                              goedh452 @najtram
                              @najtram Ow great! I was thinking of making it an option, but if this solves it for you that’s fine of course.
                              • G
                                goedh452 @steps39
                                @steps39
                                I tested with a dummy device in Domoticz I created based on your setup and think I got it working. New code is available on GitHub. Could you please check if it is working for you too?
                                • steps39S
                                  steps39 @goedh452
                                  @goedh452 brilliant works perfectly now and with the custom.css I can remove the extra title.
                                  So I now have my Household and Heat Pump usages plus Solar generation all displayed, thanks.
                                  • G
                                    goedh452 @steps39
                                    @steps39 That’s great!
                                    • N
                                      najtram
                                      Tweaking ;-)
                                      Mind the m³ instead of the m3.
                                      And the sum symbol for today: ∑
                                      And the poweroutlet symbol in domoticz name: ⚇
                                      And the ↯ for electicity.
                                      And the ☀ for the sun.
                                      Kind of bug? → Edited the Zero state for electricity. The Gauge minimum value didn’t work when set to 0.
                                      Enjoy if this fits your taste…
                                      G steps39S 2 Replies Last reply
                                      • G
                                        goedh452 @najtram
                                        @najtram Looks nice!
                                        I’ll look into the zero-bug.
                                        • N
                                          najtram @goedh452
                                          @goedh452
                                          Do you have an idea for a flame symbol instead of the text Gas. Maybe with Fontawesome?
                                          • G
                                            goedh452 @najtram
                                            @najtram
                                            The name of the device in Domoticz is used. Would you like me to built an option to use a custom header with FontAwesome?
                                            • 1 / 7
