    MMM-Domoticz-ext: interact with Domoticz
    121 Posts 14 Posters 117.6k Views 16 Watching
    • steps39S Offline
      steps39 @goedh452
      @goedh452 thank you very much, a couple of examples below.
      My Owl device measures watts, but each time I change the batteries it get a new idx, so I use a Lua script in Domoticz to capture the values and post-process before displaying as a Solar below:
         "ActTime" : 1617792992,
         "AstrTwilightEnd" : "22:07",
         "AstrTwilightStart" : "04:07",
         "CivTwilightEnd" : "20:30",
         "CivTwilightStart" : "05:44",
         "DayLength" : "13:31",
         "NautTwilightEnd" : "21:16",
         "NautTwilightStart" : "04:59",
         "ServerTime" : "2021-04-07 11:56:32",
         "SunAtSouth" : "13:07",
         "Sunrise" : "06:21",
         "Sunset" : "19:53",
         "app_version" : "4.10717",
         "result" : [
               "AddjMulti" : 1.0,
               "AddjMulti2" : 1.0,
               "AddjValue" : 0.0,
               "AddjValue2" : 0.0,
               "BatteryLevel" : 255,
               "CounterToday" : "6.210 kWh",
               "CustomImage" : 0,
               "Data" : "39023.996 kWh",
               "Description" : "",
               "EnergyMeterMode" : "",
               "Favorite" : 1,
               "HardwareID" : 3,
               "HardwareName" : "DUMMY",
               "HardwareType" : "Dummy (Does nothing, use for virtual switches only)",
               "HardwareTypeVal" : 15,
               "HaveTimeout" : false,
               "ID" : "00014179",
               "LastUpdate" : "2021-04-07 11:56:30",
               "Name" : "Solar",
               "Notifications" : "false",
               "PlanID" : "0",
               "PlanIDs" : [ 0 ],
               "Protected" : false,
               "ShowNotifications" : true,
               "SignalLevel" : "-",
               "SubType" : "kWh",
               "SwitchTypeVal" : 0,
               "Timers" : "false",
               "Type" : "General",
               "TypeImg" : "current",
               "Unit" : 1,
               "Usage" : "1409.4 Watt",
               "Used" : 1,
               "XOffset" : "0",
               "YOffset" : "0",
               "idx" : "298"
         "status" : "OK",
         "title" : "Devices"
      The raw Owl device returns 3 power readings, one from each current clamp:
         "ActTime" : 1617793340,
         "ServerTime" : "2021-04-07 12:02:20",
         "Sunset" : "19:53",
         "result" : [
               "AddjMulti" : 1.0,
               "AddjMulti2" : 1.0,
               "AddjValue" : 0.0,
               "AddjValue2" : 0.0,
               "BatteryLevel" : 100,
               "CustomImage" : 0,
               "Data" : "506 Watt, 138 Watt, 1863 Watt",
               "Description" : "",
               "Favorite" : 0,
               "HardwareID" : 1,
               "HardwareName" : "RFXCOM",
               "HardwareType" : "RFXCOM - RFXtrx433 USB 433.92MHz Transceiver",
               "HardwareTypeVal" : 1,
               "ID" : "6700",
               "LastUpdate" : "2021-04-07 12:02:12",
               "Name" : "Owl",
               "Notifications" : "true",
               "PlanID" : "0",
               "PlanIDs" : [ 0 ],
               "SignalLevel" : 7,
               "SubType" : "CM113, Electrisave",
               "Timers" : "false",
               "Type" : "Current",
               "Unit" : 0,
               "Used" : 1,
               "XOffset" : "0",
               "YOffset" : "0",
               "displaytype" : 1,
               "idx" : "1286"
         "status" : "OK",
         "title" : "Devices"
      G 2 Replies Last reply Reply Quote 0
      • G Offline
        goedh452 @steps39
        @steps39
        Thanks! I’ll look into it. A quick glance indicates that the subtype of the solar device is ‘kWh’ and the module scans for a subtype ‘Energy’. This is easy to modify in the code. The Owl device is a bit more complicated since it has the data-attribute, but does not split this into 3 separate attributes.
        I’ll let you know if I’ve something for you to test!
        • G Offline
          goedh452 @steps39
          @steps39
          Could you please pull the latest code from GitHub and check if the Solar device works now?
          steps39S 1 Reply Last reply Reply Quote 0
          • steps39S Offline
            steps39 @goedh452
            @goedh452 thanks, I had a go but it just display “Loading…” under the DOMOTICZ module label.
            I have simplified my config.js to just have this in the Domoticz module:
                              module: "MMM-Domoticz-ext",
                              header: "Domoticz",
                              position: "top_center",
                                apiBase: "192.168.89.174",
                                apiPort: "8080",
                                updateInterval: 10,
                                displayType: "all",
                                rooms: [
                                  { idx: "3" }
                                utilities: {
                                  devices: [ "301" ],
                                  utilityLabel: "Solar",
                                  counterTodayLabel: "Vandaag",
                                  gaugeWidth: 200,
                                  gaugeEnergyMinValue: -3000,
                                  gaugeEnergyMaxValue: 3000,
                                  gaugeEnergyAppendText: "Watt",
                                  useColors: true,
            • N Offline
              najtram
              Would it be possible to hide the sub headers?
              The Utilities title doesn’t fit my minimal approach. The titles of the gauges tells enough (for me)
              • N Offline
                najtram @najtram
                @najtram
                I tried:
                p.title.bright.domoCenterCell {
                  display: none;
                hr.domoDivider {
                  display: none;
                in custom.css… that worked. → Solved!
                • G Offline
                  goedh452 @najtram
                  @najtram Ow great! I was thinking of making it an option, but if this solves it for you that’s fine of course.
                  • G Offline
                    goedh452 @steps39
                    @steps39
                    I tested with a dummy device in Domoticz I created based on your setup and think I got it working. New code is available on GitHub. Could you please check if it is working for you too?
                    • steps39S Offline
                      steps39 @goedh452
                      @goedh452 brilliant works perfectly now and with the custom.css I can remove the extra title.
                      So I now have my Household and Heat Pump usages plus Solar generation all displayed, thanks.
                      • G Offline
                        goedh452 @steps39
                        @steps39 That’s great!
                        • N Offline
                          najtram
                          Tweaking ;-)
                          Mind the m³ instead of the m3.
                          And the sum symbol for today: ∑
                          And the poweroutlet symbol in domoticz name: ⚇
                          And the ↯ for electicity.
                          And the ☀ for the sun.
                          Kind of bug? → Edited the Zero state for electricity. The Gauge minimum value didn’t work when set to 0.
                          Enjoy if this fits your taste…
                          G steps39S 2 Replies Last reply Reply Quote 0
                          • G Offline
                            goedh452 @najtram
                            @najtram Looks nice!
                            I’ll look into the zero-bug.
                            • N Offline
                              najtram @goedh452
                              @goedh452
                              Do you have an idea for a flame symbol instead of the text Gas. Maybe with Fontawesome?
                              • G Offline
                                goedh452 @najtram
                                @najtram
                                The name of the device in Domoticz is used. Would you like me to built an option to use a custom header with FontAwesome?
                                • steps39S Offline
                                  steps39 @najtram
                                  @najtram great fix, how did you fix the Zero state and change the symbols, could you upload as an issue on github?
                                  steps39S N 2 Replies Last reply Reply Quote 0
                                  • steps39S Offline
                                    steps39 @steps39
                                    @najtram I hacked it by changing line 933 of MMM-Domoticz-ext centreZero from true to false, so I guess more of a fork or feature request to have the option to change the gauge style rather than a bug.
                                    • G Offline
                                      goedh452 @steps39
                                      @steps39
                                      I’ll have a look at the requests and zero state bug later this week or this weekend. Can you describe them zero state bug in more detail? Is it that when the value is zero the gauge is not displayed (correctly)?
                                      • steps39S Offline
                                        steps39 @goedh452
                                        @goedh452 I think that for both me and possibly @najtram we really want to have options which you haven’t built into your code.
                                        So, just speaking for me, the zero bug isn’t really a bug, but I want the gauge to start with zero as the bottom anti-clockwise, as I don’t want to display negative values only positive values, as @najtram shows in his figure
                                        I have got the same display of the gauge by change line 933:
                                        MMM-Domoticz-ext.js:933:    centerZero: true,
                                        to:
                                        MMM-Domoticz-ext.js:933:    centerZero: false,
                                        It would nice to have an option to choose where zero would be, and possibly a number of other options around size. But would this just make it too complex and should I be using a different tool rather than MagicMirror?
                                        So having discovered Dashticz I am wondering whether I wouldn’t be better off using Dashticz as a lot of the information I want to display comes directly from Domoticz.
                                        • G Offline
                                          goedh452 @steps39
                                          @steps39
                                          Thanks for the explanation. I’ll make some modifications and let you now.
                                          There are several options for the gauge, but they I didn’t implement it in such a way that they can be set in the config. For instance line thicknesses, etc.
                                          Dashticz is also a good option. In some ways it is more flexible, but in other ways not. But I would definitely give it a try!
                                          • N Offline
                                            najtram @goedh452
                                            @goedh452 & @steps39
                                            The “problem” with the centerZero value is relative.
                                            I tried the gaugeEnergyMinValue in the config.js and assumed this should do the trick. (So with a min value of 0 or -1 and a max value of 3000).
                                            That didn’t work. So somehow I’m not able to point out what the bug is, but I expected it to work diffrently because of the gaugeEnergyMinValue.
                                            My solution was exactly as @steps39 described in his previous post.
                                            And about the gas flame, I’m also not sure, but maybe a default replacement for default text? So water to a water sybol, gas to a flame, etc. But this is not a big issue, I’m already used to it like this. Looks nice!
                                            • 2 / 7
