    Can I setup and install magic mirror on a 3B+ and have it boot on a ZeroW?
    3 Posts 2 Posters 780 Views 2 Watching
    • J
      jamaces
      If I follow this thread and install on a new SD card using a 3B+ would it work plug and play on a ZeroW?
      https://forum.magicmirror.builders/topic/11961/installing-magicmirror-on-your-raspberry-pi-zero-w
        sdetweil @jamaces
        @jamaces if you cut a new card on pi? yes, code runs on pi0-pi4, armv6-armv7
        use my installer script for pi 0… see here
        well, if you do all the setup on on the 3b,… no it won’t run on pi0…
        3b is armv7, and pi0 is armv6
        you would have to reinstall mm… i don’t know if card would boot, but probably…
        also, there is no electron for armv6 anymore, so my script sets it up to run server and use chromium for display… the setup stuff is not provided in the base MM package anymore
        J 1 Reply Last reply
        • J
          jamaces @sdetweil
          @sdetweil this forum is amazing. Thank you.
