    MMM-Stock Cannot read property 'toLowerCase'
    34 Posts 2 Posters 15.2k Views 2 Watching
    • B
      brendan_c23
      Stock module used to run just fine, now I am given this error when pulling up ‘npm start dev’ can anyone offer any guidance on how to fix this?
        sdetweil @brendan_c23
        @brendan_c23 usually this happens when a module retrieves data and EXPECTS success, but never really checks, or the data changes format.
        this specific error is related to a string (“abcdefgh”) and wanting to convert all the chars to lowercase before comapring… BUT the string didn’t get created…
        in json data its like this
        if(json_data.key.toLowerCase() ==‘test’)
        but the item changed name to Key, so its undefined.toLowercase()…
        or key is not a string anymore,
        but an object {}
        net, the code has to change
        B 1 Reply Last reply
        Reply Quote 1
        • B
          brendan_c23 @sdetweil
          @sdetweil Could you help guide me on how to fix the code? Would you like me to post the .js file?
          S 2 Replies Last reply
            @brendan_c23 which module is that
            this one works fine (with the example stocks)
            https://github.com/hakanmhmd/MMM-Stock
              @brendan_c23 ok, I see the error on refresh…
              change line 90 from
              	if(this.config.currency.toLowerCase() != "usd"){
              to
              	if(that.config.currency.toLowerCase() != "usd"){
              Reply Quote 1
              • B
                @sdetweil Hey I tried that, now it says Cannot read property ‘toLowerCase’ of undefined at MMM-stock.js:90
                Any other suggestions?
                u are only changing the word this to the word that on that one line
                • B
                  brendan_c23 @brendan_c23
                  @brendan_c23 Uncaught TypeError: Cannot read property ‘toLowerCase’ of undefined
                    @brendan_c23 you are only changing one word
                    ‘this’ to the word ‘that’ on one line
                    • B
                      @sdetweil Yes I made that change, but the error was still coming up for me
                        @brendan_c23 show me those 10 lines
                        • B
                          @sdetweil //if another currency is required - usd is default
                          var differentCurrency = false;
                          if(that.config.currency.toLowerCase() != “usd”){
                          differentCurrency = true;
                          var requiredCurrency = this.config.currency.toUpperCase();
                          	for (var key in data) {
                          		if (!data.hasOwnProperty(key)) {continue;}
                          		var symbol = key;
                          		var obj = data[key];
                          		var current = obj[0];
                          		var prev = obj[1];
                          		var price = current["4. close"];
                          		var change = prev["4. close"] - current["4. close"];
                          		var html = "";
                          		var priceClass = "greentext", priceIcon="up_green";
                          		if(change < 0) {
                          			priceClass = "redtext";
                          			priceIcon="down_red";
                            @brendan_c23 no, these, around line 90
                            	scheduleUpdate: function(delay) {
                            		var loadTime = this.config.updateInterval;
                            		if (typeof delay !== "undefined" && delay >= 0) {
                            			loadTime = delay;
                            		var that = this;
                            		setInterval(function() {
                            			that.getStocks();
                            			if(that.config.currency.toLowerCase() != "usd"){ // line 90 changed
                            				that.getExchangeRate();
                            		}, loadTime);
                            • B
                              @sdetweil Ok, I changed the ‘this’ to ‘that’ some lines above! not on those lines, going to try running it after changing the line you just sent
                                @brendan_c23 just the ONE line, line 90…
                                Reply Quote 1
                                • B
                                  brendan_c23
                                  @sdetweil still waiting to see if it will display, theres a big delay, but no errors have popped up yet
                                  if (typeof delay !== “undefined” && delay >= 0) {
                                  loadTime = delay;
                                  	var that = this;
                                  		that.getStocks();
                                  	}, loadTime);
                                  • B
                                    @sdetweil No errors have come up, but it also has not displayed, have been waiting for around 10 minutes
                                      @brendan_c23 did u change the other lines back?
                                      open the developers window ctrl-shift-i, console tab, ‘stock’ in the filter field (no quotes)
                                      B 2 Replies Last reply
                                      • B
                                        @sdetweil They should be, but just in case Im missing something…
                                        Module.register(“MMM-Stock”, {
                                        result: {},
                                        defaults: {
                                        updateInterval: 60000,
                                        fadeSpeed: 1000,
                                        companies: [“GOOGL”, “YHOO”],
                                        currency: “usd”,
                                        baseURL: “https://www.alphavantage.co/”,
                                        apikey: “IPWULBT54Y3LHJME”
                                        getStyles: function() {
                                        	return ["MMM-Stock.css"];
                                        getTranslations: function() {
                                        	return false;
                                        start: function() {
                                        	this.getStocks();
                                        		this.getExchangeRate();
                                        	this.scheduleUpdate();
                                        getDom: function() {
                                        	wrapper.className = "quotes";
                                        	var list = document.createElement("ul");
                                        	var data = this.result;
                                        	// the data is not ready
                                        	if(Object.keys(data).length === 0 && data.constructor === Object){
                                        		return wrapper;
                                        		var symbol = key;
                                        		var prev = obj[1];
                                        		var html = "";
                                        		if(change < 0) {
                                        		html = html + "<span class='" + priceClass + "'>";
                                        		html = html + "<span class='quote'> (" + symbol + ")</span> ";
                                        		html = html + parseFloat(price).toFixed(2) + " USD";
                                        		html = html + "<span class='" + priceIcon + "'></span>" + parseFloat(Math.abs(change)).toFixed(2);
                                        		var stock = document.createElement("span");
                                        		stock.className = "stockTicker";
                                        		stock.innerHTML = html;
                                        		var listItem = document.createElement("li");
                                        		listItem.innerHTML = html;
                                        		list.appendChild(listItem);
                                        	wrapper.appendChild(list);
                                        	return wrapper;
                                        		loadTime = delay;
                                        	var that = this;
                                        		that.getStocks();
                                        	}, loadTime);
                                        getStocks: function () {
                                        	var allCompanies = this.config.companies;
                                        	var urls = [];
                                        	for(var company in allCompanies){
                                        		var url = this.config.baseURL + "query?function=TIME_SERIES_DAILY&outputsize=compact&symbol=" + allCompanies[company] + "&apikey=" + this.config.apikey;
                                        		urls.push(url);
                                        	this.sendSocketNotification("GET_STOCKS", urls);
                                        getExchangeRate: function () {
                                        	var url = this.config.baseURL + "?q=select%20*%20from%20yahoo.finance.xchange%20where%20pair%20in%20('USD" + this.config.currency + "')&format=json&diagnostics=true&env=store%3A%2F%2Fdatatables.org%2Falltableswithkeys&callback="
                                        	this.sendSocketNotification("GET_EXCHANGE_RATE", url);
                                        	if (notification === "STOCK_RESULT") {
                                        		this.result = payload;
                                        		this.updateDom(self.config.fadeSpeed);
                                        	} else if(notification === "EXCHANGE_RATE"){
                                        		this.rate = payload;
                                        • B
                                          @sdetweil Load script: modules/MMM-Stock//MMM-Stock.js
                                          module.js:517 Module registered: MMM-Stock
                                          loader.js:148 Bootstrapping module: MMM-Stock
                                          loader.js:153 Scripts loaded for: MMM-Stock
                                          loader.js:195 Load stylesheet: modules/MMM-Stock/MMM-Stock.css
                                          loader.js:155 Styles loaded for: MMM-Stock
                                          loader.js:157 Translations loaded for: MMM-Stock
                                            @brendan_c23 so, no errors
                                            does the config entry have a position:
                                            if not the content is thrown away
