    Compliments: RemoteFile Configuration
    complimentsremotefileconfiguration
    8 Posts 5 Posters 2.2k Views 5 Watching
      jacktar
      Hi…
      I don’t consider myself to be a novice but setting up a remote compliments file is proving to be a real challenge.
      Unfortunately, IMO the documentation isn’t that great when targetting a remote file - I’ve tried all sorts of config lines but to no avail.
      e.g.
      remoteFile: 'http://localhost:8080/compliments.json'
      remoteFile: 'http://localhost:8080/modules/compliments.json'
      for localhost, also read 127.0.0.1 and its assigned IPv4 address - I even moved the file into different directories in the vain hope it was a webserver permissions problem.
      This is the (current) error in the debug window using localhost…
      Access to XMLHttpRequest at 'http://localhost:8080/compliments.json' from origin 'http://0.0.0.0:8080' has been blocked by CORS policy: No 'Access-Control-Allow-Origin' header is present on the requested resource.
      compliments.js:134
      GET http://localhost:8080/compliments.json net::ERR_FAILED
      Similarly, I also tried…
      remoteFile: 'file://home/pi/MagicMirror/compliments.json'
      ALL ATTEMPTS to target a filesystem file (compliments.json) fail :( …
      compliments.js:134 GET http://0.0.0.0:8080/modules/default/compliments/file://home/pi/MagicMirror/compliments.json 404 (Not Found)
      I can only assume my notation is wrong somewhere/somehow!
      Incidentally, the file formatting appears to be correct so I’m convinced it’s the way I’m trying to ‘point’ the system at the json file.
      If anyone can help, I’d appreciate it. Not much hair left to pull out :(
      lavolp3L 2 Replies Last reply Reply Quote 0
      • lavolp3L Offline
        lavolp3 Module Developer @jacktar
        @jacktar said in Compliments: RemoteFile Configuration:
        You see the problem in the error message.
        The variable remoteFilegets appended to an existing path which is http://0.0.0.0:8080/modules/default/compliments/.
        You only need to put in the name of the file without a path and put your file into the compliments folder.
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
        • lavolp3L Offline
          @jacktar Here is the underlying function
          	/* complimentFile(callback)
          	 * Retrieve a file from the local filesystem
          	complimentFile: function (callback) {
          		var xobj = new XMLHttpRequest(),
          			isRemote = this.config.remoteFile.indexOf("http://") === 0 || this.config.remoteFile.indexOf("https://") === 0,
          			path = isRemote ? this.config.remoteFile : this.file(this.config.remoteFile);
          		xobj.overrideMimeType("application/json");
          		xobj.open("GET", path, true);
          		xobj.onreadystatechange = function () {
          			if (xobj.readyState === 4 && xobj.status === 200) {
          				callback(xobj.responseText);
          		xobj.send(null);
          Whenever you use a “http://” or “https://” path it takes the path as you have provided. If not it converts it to an absolute path using the this.file(this.config.remoteFile) method. This method uses the modules directory (like you can see in my post above) and appends the path you have given
          S J 2 Replies Last reply Reply Quote 0
            sdetweil @lavolp3
            @lavolp3 another thing to say is
            the MagicMirror provided web server assumes
            modules is the root
            express is listening/watching for modules as the base path
            http://localhost:8080/modules/…
            the file can be anywhere further down
              jacktar @lavolp3
              Ok, thanks. Got that sorted now :)
              Hopefully this will help others with the same dilemma.
              I had read a post referencing the use of file://
              notation which, apparently, is a red-herring.
              Just for clarity to others, a local compliments.json
              file should be located in /pi/MagicMirror/modules/default/compliments/ directory and referenced using only the file name in the config file.
              e.g. remoteFile: 'compliments.json'
              kayakbabeK 1 Reply Last reply Reply Quote 0
              • kayakbabeK Offline
                kayakbabe @jacktar
                e.g. remoteFile: ‘compliments.json’
                So… what happens if we update the compliments module? Do our customizations in the compliments.json file get wiped out?
                can we put the compliments.json somewhere else to protect it?
                  sdetweil @kayakbabe
                  @kayakbabe yes they will be lost.
                  .NEVER edit the source files we provide.
                  the design is that all your setting go in config.js
                  and custom.css for colors etc.
                  module :"compliments",
                  position:"....",
                  config:{
                      compliments:{
                                 morning:[],
                                  afternoon:[],
                                etc
                  • AssassinsA Offline
                    Assassins
                    You can look here
