    Compliments: RemoteFile Configuration
    complimentsremotefileconfiguration
    8 Posts 5 Posters 2.4k Views 5 Watching
    • lavolp3L Offline
      lavolp3 Module Developer @jacktar
      @jacktar said in Compliments: RemoteFile Configuration:
      compliments.js:134 GET http://0.0.0.0:8080/modules/default/compliments/file://home/pi/MagicMirror/compliments.json 404 (Not Found)
      You see the problem in the error message.
      The variable remoteFilegets appended to an existing path which is http://0.0.0.0:8080/modules/default/compliments/.
      You only need to put in the name of the file without a path and put your file into the compliments folder.
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
      • lavolp3L Offline
        @jacktar Here is the underlying function
        	/* complimentFile(callback)
        	 * Retrieve a file from the local filesystem
        	complimentFile: function (callback) {
        		var xobj = new XMLHttpRequest(),
        			isRemote = this.config.remoteFile.indexOf("http://") === 0 || this.config.remoteFile.indexOf("https://") === 0,
        			path = isRemote ? this.config.remoteFile : this.file(this.config.remoteFile);
        		xobj.overrideMimeType("application/json");
        		xobj.open("GET", path, true);
        		xobj.onreadystatechange = function () {
        			if (xobj.readyState === 4 && xobj.status === 200) {
        				callback(xobj.responseText);
        		xobj.send(null);
        Whenever you use a “http://” or “https://” path it takes the path as you have provided. If not it converts it to an absolute path using the this.file(this.config.remoteFile) method. This method uses the modules directory (like you can see in my post above) and appends the path you have given
        S J 2 Replies Last reply Reply Quote 0
          sdetweil @lavolp3
          @lavolp3 another thing to say is
          the MagicMirror provided web server assumes
          modules is the root
          express is listening/watching for modules as the base path
          http://localhost:8080/modules/…
          the file can be anywhere further down
            jacktar @lavolp3
            Ok, thanks. Got that sorted now :)
            Hopefully this will help others with the same dilemma.
            I had read a post referencing the use of file://
            notation which, apparently, is a red-herring.
            Just for clarity to others, a local compliments.json
            file should be located in /pi/MagicMirror/modules/default/compliments/ directory and referenced using only the file name in the config file.
            e.g. remoteFile: 'compliments.json'
            kayakbabeK 1 Reply Last reply Reply Quote 0
            • kayakbabeK Offline
              kayakbabe @jacktar
              e.g. remoteFile: ‘compliments.json’
              So… what happens if we update the compliments module? Do our customizations in the compliments.json file get wiped out?
              can we put the compliments.json somewhere else to protect it?
                sdetweil @kayakbabe
                @kayakbabe yes they will be lost.
                .NEVER edit the source files we provide.
                the design is that all your setting go in config.js
                and custom.css for colors etc.
                module :"compliments",
                position:"....",
                config:{
                    compliments:{
                               morning:[],
                                afternoon:[],
                              etc
                • AssassinsA Offline
                  Assassins
                  You can look here
