    Problems restarting MagicMirror (Port 8080 in use ...)
    20 Posts 7 Posters 13.3k Views 7 Watching
      roramirez Core Contributors @binderth
      @binderth said in Problems restarting MagicMirror (Port 8080 in use ...):
      Do I need pm2?
      Is optional. If you installed by script and choice. After that you can configurate mannually.
      Easy module development with MagicMirror Module Template
        roramirez Core Contributors @ostfilinchen
        @ostfilinchen That version don’t have the feature for use pm2 for process control by installer script. What is your problem in 2.1.0?
        • O Offline
          ostfilinchen @roramirez
          @roramirez my Problem is this error
          8080 at Object.exports._errnoException (util.js:1026:11) at exports._exceptionWithHostPort (util.js:1049:20) at Server._listen2 (net.js:1253:14) at listen (net.js:1289:10) at net.js:1399:9 at _combinedTickCallback (internal/process/next_tick.js:77:11) at process._tickCallback (internal/process/next_tick.js:98:9) at Module.runMain (module.js:592:11) at run (bootstrap_node.js:402:7) at startup (bootstrap_node.js:157:9) code: 'EADDRINUSE', errno: 'EADDRINUSE', syscall: 'listen', address: '::', port: 8080 }
          when i restart the mirror via pm2
          • cowboysdudeC Offline
            cowboysdude Module Developer
            Thanks guys!
              @ostfilinchen What pm2 version are using?. There are other process to start control of MagicMirror?
              Please, send some log lines of pm2 and what show you
              pm2 status
              • O Offline
                @roramirez i think the Problem is the pm2. My in Memory Version is 2.0.19 and my local Version is 2.3.0.
                if i do pm2 update it updates the Version, but if i restart the pi, i have 2 Versions again.
                  @ostfilinchen So stranger. What is for you memory version?
                  Note: The last stable release of pm2 is 2.2.1.
                  I recomend use the last version stable. In my case, the 2.1.5, work fine the restart action.
                  • O Offline
                    @roramirez thanks for the Information. how can i update to 2.1.5?
                      @ostfilinchen by npm
                      sudo npm install -g pm2@2.1.5
                      First remove previous version installed
                      https://docs.npmjs.com/cli/uninstall
                      • O Offline
                        @roramirez i’ve done this and have a look on the restartprocess in the next time. thanks a lot.
