    Problems restarting MagicMirror (Port 8080 in use ...)
    20 Posts 7 Posters 15.3k Views 7 Watching
      roramirez Core Contributors
      Ups, there a bug for pm2 config. I pushed a fix
      https://github.com/MichMich/MagicMirror/pull/640
      The restart is work for me. Are you try stop/start?
      pi@raspberrypi:~/MagicMirror $ pm2 status MagicMirror
      │ App name    │ id │ mode │ pid  │ status │ restart │ uptime │ cpu │ mem      │ watching │
      │ MagicMirror │ 0  │ fork │ 7689 │ online │ 1       │ 3h     │ 0%  │ 2.4 MB   │  enabled │
       Use `pm2 show ` to get more details about an app
      pi@raspberrypi:~/MagicMirror $ pm2 restart MagicMirror
      Restarts are now immutable, to update environment or conf use --update-env
      [PM2] Applying action restartProcessId on app [MagicMirror](ids: 0)
      [PM2] [MagicMirror](0) ✓
      │ MagicMirror │ 0  │ fork │ 6447 │ online │ 2       │ 0s     │ 7%  │ 2.3 MB   │  enabled │
      By the way, there a interesting notice in restart process by pm2
      Here I’m using 2.1.5 version
      pi@raspberrypi:~/MagicMirror $ pm2 -version
      2.1.5
      B O 2 Replies Last reply
        binderth @roramirez
        @roramirez said in Problems restarting MagicMirror (Port 8080 in use ...):
        2.1.5
        Do I need pm2?
        pi@MagicMirror:~ $ pm2 -version
        -bash: pm2: Kommando nicht gefunden.
        (translates: command not found)
        R 1 Reply Last reply
        • O
          ostfilinchen @roramirez
          @roramirez what i have to do to get the fix from github? I have installed MM v2.1.0
          • MichMichM
            MichMich
            This seem to have fixed the issue. Thanks @roramirez!
              roramirez Core Contributors @binderth
              @binderth said in Problems restarting MagicMirror (Port 8080 in use ...):
              Do I need pm2?
              Is optional. If you installed by script and choice. After that you can configurate mannually.
                roramirez Core Contributors @ostfilinchen
                @ostfilinchen That version don’t have the feature for use pm2 for process control by installer script. What is your problem in 2.1.0?
                O 1 Reply Last reply
                • O
                  @roramirez my Problem is this error
                  8080 at Object.exports._errnoException (util.js:1026:11) at exports._exceptionWithHostPort (util.js:1049:20) at Server._listen2 (net.js:1253:14) at listen (net.js:1289:10) at net.js:1399:9 at _combinedTickCallback (internal/process/next_tick.js:77:11) at process._tickCallback (internal/process/next_tick.js:98:9) at Module.runMain (module.js:592:11) at run (bootstrap_node.js:402:7) at startup (bootstrap_node.js:157:9) code: 'EADDRINUSE', errno: 'EADDRINUSE', syscall: 'listen', address: '::', port: 8080 }
                  when i restart the mirror via pm2
                  • cowboysdudeC
                    Thanks guys!
                      @ostfilinchen What pm2 version are using?. There are other process to start control of MagicMirror?
                      Please, send some log lines of pm2 and what show you
                      pm2 status
                      • O
                        @roramirez i think the Problem is the pm2. My in Memory Version is 2.0.19 and my local Version is 2.3.0.
                        if i do pm2 update it updates the Version, but if i restart the pi, i have 2 Versions again.
                          @ostfilinchen So stranger. What is for you memory version?
                          Note: The last stable release of pm2 is 2.2.1.
                          I recomend use the last version stable. In my case, the 2.1.5, work fine the restart action.
                          • O
                            @roramirez thanks for the Information. how can i update to 2.1.5?
                              @ostfilinchen by npm
                              sudo npm install -g pm2@2.1.5
                              First remove previous version installed
                              https://docs.npmjs.com/cli/uninstall
                              • O
                                @roramirez i’ve done this and have a look on the restartprocess in the next time. thanks a lot.
