    Problems restarting MagicMirror (Port 8080 in use ...)
    20 Posts 7 Posters 13.9k Views 7 Watching
    • binderthB Offline
      binderth
      Same for me, if you mean this Messages (I’m using the main 2.1):
      pi@MagicMirror:~/MagicMirror $ DISPLAY=:0 npm restart &
      [1] 29215
      > magicmirror@2.1.0 start /home/pi/MagicMirror
      > electron js/electron.js
      Starting MagicMirror: v2.1.0
      Loading config ...
      Loading module helpers ...
      No helper found for module: MMM-Globe.
      No helper found for module: MMM-Callmonitor-Current-Call.
      All module helpers loaded.
      Starting server op port 8080 ...
      Server started ...
      Connecting socket for: MMM-PIR-Sensor
      Staring module helper: MMM-PIR-Sensor
      Connecting socket for: MMM-Wunderlist
      Connecting socket for: MMM-FRITZ-Box-Callmonitor
      Starting module: MMM-FRITZ-Box-Callmonitor
      Connecting socket for: MMM-DWD-WarnWeather
      MMM-DWD-WarnWeather helper started...
      Connecting socket for: MMM-NetworkScanner
      Starting module: MMM-NetworkScanner
      Starting module: newsfeed
      { Error: listen EADDRINUSE :::8080
          at Object.exports._errnoException (util.js:1026:11)
          at exports._exceptionWithHostPort (util.js:1049:20)
          at Server._listen2 (net.js:1253:14)
          at listen (net.js:1289:10)
          at net.js:1399:9
          at _combinedTickCallback (internal/process/next_tick.js:77:11)
          at process._tickCallback (internal/process/next_tick.js:98:9)
          at Module.runMain (module.js:592:11)
          at run (bootstrap_node.js:402:7)
          at startup (bootstrap_node.js:157:9)
        code: 'EADDRINUSE',
        errno: 'EADDRINUSE',
        syscall: 'listen',
        address: '::',
        port: 8080 }
      Launching application.
        roramirez Core Contributors
        Ups, there a bug for pm2 config. I pushed a fix
        https://github.com/MichMich/MagicMirror/pull/640
        The restart is work for me. Are you try stop/start?
        pi@raspberrypi:~/MagicMirror $ pm2 status MagicMirror
        │ App name    │ id │ mode │ pid  │ status │ restart │ uptime │ cpu │ mem      │ watching │
        │ MagicMirror │ 0  │ fork │ 7689 │ online │ 1       │ 3h     │ 0%  │ 2.4 MB   │  enabled │
         Use `pm2 show ` to get more details about an app
        pi@raspberrypi:~/MagicMirror $ pm2 restart MagicMirror
        Restarts are now immutable, to update environment or conf use --update-env
        [PM2] Applying action restartProcessId on app [MagicMirror](ids: 0)
        [PM2] [MagicMirror](0) ✓
        │ MagicMirror │ 0  │ fork │ 6447 │ online │ 2       │ 0s     │ 7%  │ 2.3 MB   │  enabled │
        By the way, there a interesting notice in restart process by pm2
        Here I’m using 2.1.5 version
        pi@raspberrypi:~/MagicMirror $ pm2 -version
        2.1.5
        binderthB O 2 Replies Last reply Reply Quote 0
        • binderthB Offline
          binderth @roramirez
          @roramirez said in Problems restarting MagicMirror (Port 8080 in use ...):
          2.1.5
          Do I need pm2?
          pi@MagicMirror:~ $ pm2 -version
          -bash: pm2: Kommando nicht gefunden.
          (translates: command not found)
          • O Offline
            ostfilinchen @roramirez
            @roramirez what i have to do to get the fix from github? I have installed MM v2.1.0
            • MichMichM Offline
              MichMich
              This seem to have fixed the issue. Thanks @roramirez!
                roramirez Core Contributors @binderth
                @binderth said in Problems restarting MagicMirror (Port 8080 in use ...):
                Do I need pm2?
                Is optional. If you installed by script and choice. After that you can configurate mannually.
                  roramirez Core Contributors @ostfilinchen
                  @ostfilinchen That version don’t have the feature for use pm2 for process control by installer script. What is your problem in 2.1.0?
                  • O Offline
                    @roramirez my Problem is this error
                    8080 at Object.exports._errnoException (util.js:1026:11) at exports._exceptionWithHostPort (util.js:1049:20) at Server._listen2 (net.js:1253:14) at listen (net.js:1289:10) at net.js:1399:9 at _combinedTickCallback (internal/process/next_tick.js:77:11) at process._tickCallback (internal/process/next_tick.js:98:9) at Module.runMain (module.js:592:11) at run (bootstrap_node.js:402:7) at startup (bootstrap_node.js:157:9) code: 'EADDRINUSE', errno: 'EADDRINUSE', syscall: 'listen', address: '::', port: 8080 }
                    when i restart the mirror via pm2
                    • cowboysdudeC Offline
                      Thanks guys!
                        @ostfilinchen What pm2 version are using?. There are other process to start control of MagicMirror?
                        Please, send some log lines of pm2 and what show you
                        pm2 status
