    SD Card - no Space
    15 Posts 4 Posters 5.4k Views 4 Watching
    • C Offline
      c1olli
      Hello,
      In the last months the SD card (32GB) of the MM were after 2 weeks full of data.
      I tried 3 times to find the problem, but at least I made it completly new.
      Today the SD card was full again and I found out, that the MagicMirror-error.log was about 24GB big.
      So I deleted it and the system is working again.
      But why was it so big? Because of the amount of data I could not open ist.
        sdetweil @c1olli
        @c1olli edit the config.js and remove debug from the logLevel:[] list
        like this (remove “DEBUG”)
        logLevel: ["INFO", "LOG", "WARN", "ERROR"],
        supposed to be off by default…
        then pm2 flush
        then start MM again
        pm2 restart 0
        C G 2 Replies Last reply Reply Quote 0
        • C Offline
          c1olli @sdetweil
          @sdetweil said in SD Card - no Space:
          logLevel: [“INFO”, “LOG”, “WARN”, “ERROR”],
          Thanks,
          the loglevel was complete missing in the config.js, but the systems wrote logs.
          Now I added it like in your post. Let’s see what will happen.
          Is it possible to turn the logs out ? Maybe with
          loglevel: [ ], ?
            sdetweil @c1olli
            @c1olli nothing logs (at this time) except calendar for DEBUG
            • C Offline
              c1olli @sdetweil
              @sdetweil It does’nt matter what I do - the log expanses.
              So I started now a cronjob with a daily flush of the log data.
                sdetweil @c1olli
                @c1olli what is in the log?
                • C Offline
                  c1olli @sdetweil
                  That is the log from about 2 hours - more than 1 million lines.
                  And always the same.
                    sdetweil @c1olli
                    @c1olli you have a failing module.
                    MMM-Fronius
                    you should disable it until u can resolve the problem
                    C 1 Reply Last reply Reply Quote 1
                    • C Offline
                      c1olli @sdetweil
                      That solved the problem. So I will fetch the Fronius Data via MMM-ioBroker in future.
                      • G Offline
                        George @sdetweil
                        @sdetweil , hi, I think I have the same problem with the card, the mirror starts very slowly, “sudo reboot” does not always work. Please, can you explain me step by step how to remove debug?
                          sdetweil @George
                          @george https://forum.magicmirror.builders/topic/14915/sd-card-no-space/2
                          • G Offline
                            George @sdetweil
                            @sdetweil , thanks, i already read this post but i don’t know how to edit config.js list. How do I get in there? :(
                              sdetweil @George
                              @george how do you edit it to add a module? same way
                              read the link in my signature, How to add Modules
                                avolaid @c1olli
                                @c1olli said in SD Card - no Space:
                                MMM-ioBroker
                                How did you got the Fronius fork with the MMM-ioBroker?
                                • C Offline
                                  c1olli @avolaid
                                  @avolaid said in SD Card - no Space:
                                  MMM-fronius ist sending the data direktly to the Mirror.
                                  MMM-ioBroker sends my ioBroker data to the Mirror and has a adaptor to fronius.
                                  So both adaptors are working not together.
