    [Smart Home] loxone - XML - show temperature via http
    4 Posts 3 Posters 2.9k Views 3 Watching
    • elmatttE Offline
      elmattt
      Hi Guys !
      got a magic mirror since end 2015, and now upgrading the software here ^^
      i use a loxone smarthome server, and i want to show the temperature on my mirror :
      before i was using php like this :
      php   //température intérieur loxone
      $fichier = 'http://admin:XXXXXXXXXX@192.168.0.15/dev/sps/io/tempsalon';
      $xml = simplexml_load_file($fichier);
      echo $xml["value"];
      how can i simply use this with a existing module ??
      as you can see: there is an authentification in the URL !!!
      the xml generated is :
      LL control="dev/sps/io/tempsalon" value="21.0°" Code="200"/
      thanks by advance and sorry for my bad english (frenchie here :) )
      • cowboysdudeC Offline
        cowboysdude Module Developer
        Going to have to convert that to js…
        Take a look at the module development. I do not know enough about js to help you but I know that it’s how the system runs…
        Turn it into a module… :)
        I too am fluent in php not so much in js…
        • idoodlerI Offline
          idoodler Module Developer
          I am just working on MMM-Loxone, which enables exactly what you want.
          Check my post for updates!
          • idoodlerI Offline
            I just published my module MMM-Loxone:)
            [card:idoodler/MMM-Loxone]
