    MagicMirror Raspberry Pi 0 W
    9 Posts 3 Posters 3.0k Views 3 Watching
    • L Offline
      lifetech
      Hi all!
      I am very eager to create my first magic mirror. I recently got my hands on a Pi 0, and I saw a bunch of tutorials claiming that it can be done on the Zero. I quickly got to work setting it up and downloading packages.
      Twice I got stuck at the stage I am at now. When I try to boot MM from the terminal either nothing happens or I get a error. Or if I reboot into the mirror, I am able to see it booting but then it kicks me back to the desktop.
      I am very unaware what my issue could be at this point. Electron, NPM, and Node are installed and latest. Any suggestions?
      S unfriendlydeviceU 2 Replies Last reply Reply Quote 0
        sdetweil @lifetech
        @lifetech just use the install script , see
        best to start from a clean flash, with full desktop PI OS… buster(latest)
        • unfriendlydeviceU Offline
          unfriendlydevice @lifetech
          @lifetech I ran my original mirror on a Pi Zero using the image provided here: http://emmanuelcontreras.com/how-to/how-to-create-a-magic-mirror-2-with-pi-zero-w
            sdetweil @unfriendlydevice
            @unfriendlydevice don’t care… use the latest stuff… many of the docs don’t get updated (that is 2017, 4 YEARS ago(
            jessie and stretch are too old
            use buster
            use my script… there are settings that MUST be done, and u won’t have them
            electron is not available for armv6l anymore
            unfriendlydeviceU 1 Reply Last reply Reply Quote 0
              unfriendlydevice @sdetweil
              @sdetweil The image uses Chromium and was last updated April 2020, not completely up to date but definitely not from 2017!
                @unfriendlydevice ok… still doesn’t work tho… so…
                • L Offline
                  lifetech @sdetweil
                  @sdetweil it was missing alot of dependencies and giving alot of errors when I tried before. Is it a good known install?
                    sdetweil @lifetech
                    @lifetech my script is a good installer, and I will fix it if not. I support it on more platforms than MM supports
                    • L Offline
                      lifetech @sdetweil
                      @sdetweil THANKS MAN! I think I’m finally able to play around with this thing
