    Http Stream
    10 Posts 4 Posters 2.1k Views 4 Watching
    • W Offline
      wuermchen
      Hello,
      I want to show a video stream when the doorbell rings. Unfortunately, the camera only sends an Http stream.
      http://192.168.168.6/media/?action=stream?user=test&pwd=testf&resolution=128
      I tried MMM-RTSPStream, the mirror only plays rtsp streams.
      • JerryPJ Offline
        JerryP
        This works whit a webcam online. so I think this wel work also. whits type of doorbell you use?
        		module: "MMM-RTSPStream",
        		disabled: false, //false, true
        		position: "middle",
        			autoStart: true,
        			rotateStreams: false,
        			rotateStreamTimeout: 20,
        			moduleWidth: 468,
        			moduleHeight: 320,
        			localPlayer: "vlc", // "omxplayer" or "vlc"
        			remotePlayer: 'none',
        			showSnapWhenPaused: false,
        			remoteSnaps: false,
        			  stream1: {
        			  url: 'http://192.168.168.6/media/?action=stream?user=test&pwd=testf&resolution=128',
        			  protocol: "tcp",
        			  frameRate: 25,
        			  muted: true,
          sdetweil @JerryP
          @jerryp please use code blocks for config info
          mark the text, and then hit the </> button above the editor
          JerryPJ 1 Reply Last reply Reply Quote 0
          • JerryPJ Offline
            JerryP @sdetweil
            @sdetweil I know, and I use the code button. only I made a typ(O) so de code blok was not showing.
              sdetweil @JerryP
              @jerryp no problem, thanks for fixing and it helps for others to see
              • W Offline
                wuermchen
                I tried the settings. Unfortunately no success. I have a mini spy cam. The stream runs on VLC on the WinPC. But not on the Raspberry VLC. Unbenannt.JPG .
                • W Offline
                  wuermchen
                  I tried the stream on a Raspberry pi3 and it works. the settings are the same as on the Raspberry Pi4 (MagicMirror). I uninstalled and reinstalled VLC, unfortunately to no avail.
                  Does anyone have any idea what the stream is not running on the Pi4?
                  bugsounetB 1 Reply Last reply Reply Quote 0
                  • bugsounetB Offline
                    bugsounet Banned @wuermchen
                    @wuermchen
                    1. close MagicMirror and open VLC in your pi
                    2. open your link with vlc (in your pi)
                    3. verify if works ?
                    • if not works :
                      • catch error (if it say error) and solve it
                      • change output video setting in Tools > preferencies > Video > output
                      • close VLC and reopen it for retry play your link
                    • It 's work ?
                      • close VLC again
                      • Retry with magicmirror
                    • W Offline
                      wuermchen
                      following error message :
                      pi@raspberrypi:~ $ vlc http://admin:pass@192.168.188.6/media/?action=stream
                      VLC media player 3.0.12 Vetinari (revision 3.0.12-1-0-gd147bb5e7e)
                      [01273b58] main libvlc: VLC wird mit dem Standard-Interface ausgeführt. Benutzen Sie 'cvlc', um VLC ohne Interface zu verwenden.
                      libEGL warning: DRI2: failed to authenticate
                      qt5ct: using qt5ct plugin
                      qt5ct: D-Bus global menu: no
                      qt5ct: D-Bus system tray: no
                      [b391b6b0] mmal_codec decoder: VCSM init succeeded: CMA
                      [b391b6b0] mmal_codec decoder error: MMAL error 2 "ENOSPC"
                      [b391b6b0] mmal_codec decoder error: MMAL error reported by ctrl
                      [b391b6b0] main decoder error: buffer deadlock prevented
                      I can’t do anything with the error message
                      • W Offline
                        wuermchen
                        I tried all the settings. without success
