    MMM-ToDoLive doesn't respond
    9 Posts 2 Posters 1.8k Views 2 Watching
      rebecca
      Hi!
      I am very new to raspberry and magic mirror.
      I use MMM-ToDoLive module to be able to add text directly to my magic mirror. but after I installed it, nothing happened, I couldn’t delete and add text to my magic mirror.
      Please help me, thank you so much
        sdetweil @rebecca
        @rebecca when I install and add to my config.js (and use the 1st example entry)
        I see this
        and then I click on the text
        and see this
        and I can change the text where the cursor is (I have to delete the text that is there)
        I have this is my custom.css to turn the mouse pointer back on
        html {
              cursor: unset;
          rebecca
          @sdetweil i used to try this and adding cursor: unset; but still nothing happen
            rebecca @sdetweil
            nothing happen when i click the default text
            @rebecca said in MMM-ToDoLive doesn't respond:
              sdetweil @rebecca
              @rebecca what position did u set for the module?
                rebecca @sdetweil
                @sdetweil i set it to bottom-left. Does the position of the module placement take an effect ?
                  sdetweil @rebecca
                  @rebecca no idea. will test again later
                    rebecca @sdetweil
                    @sdetweil sad, but thank you soo much for kind of wasting your time trying to help me ^^
                      sdetweil @rebecca
                      @rebecca that was very rude. you could have sent me a message on chat.
