    yellow lightning and CPU
    9 Posts 3 Posters 1.8k Views 3 Watching
      RIKKO14
      Hello ,
      What does the yellow lightning at the top of my screen mean?
      on my module at the bottom left I see that the CPU is used a lot, how can I reduce its use?
      • BKeyportB Offline
        BKeyport Module Developer @RIKKO14
        @rikko14 Yellow lightning in the upper right corner is power problems. You’re not suppling enough power to the Pi.
          RIKKO14 @BKeyport
          @bkeyport Thank you for your reply.
          However I use the power supply delivered with my Pi … (Input 100-240 ~ 50 / 60Hz 0.6A, Output: 5V3000mA, 9V2000mA, 12V1500mA) And it seems to me that when I installed the Pi before the modules that was not displayed. the Pi is plugged into a power strip with only the 24 "screen and the 12V power supply for small speakers.
          What do you recommend ? Is the original power supply defective?
          S BKeyportB 2 Replies Last reply Reply Quote 0
            sdetweil @RIKKO14
            @rikko14 it happens
            • BKeyportB Offline
              I’m assuming you have a Pi 3 or older, right?
              I would power the pi via the GPIO 5V to get around the USB spec for MicroUSB that isn’t enough for the Pi.
                RIKKO14 @BKeyport
                @bkeyport I have a Pi 4 B.
                  sdetweil @RIKKO14
                  @rikko14 pi4 requires the most power
                    RIKKO14 @sdetweil
                    here is the power supply that came with the kit that I bought on Aliexpress.
                    I changed the power supply to a SMASUNG 5V2A and I no longer have this yellow lightning.
                      sdetweil @RIKKO14
                      @rikko14 2A is close. I bought some 5A supplies
