    Missing Train in MMM-NYC Transit
    3 Posts 2 Posters 750 Views 2 Watching
    • N
      Nneuland
      Re: MMM-nyc-transit
      @Elaniobro
      Elan, this module is amazing. Thank you for your hard work.
      I periodically lose one of he trains listed. It comes back eventually, but not sure wat is causing this. Any insight or suggestions into the cause would be greatly appreciated.
      Nick
        sdetweil @Nneuland
        @nneuland can u give more info?
        when, time of day
        what is the actual train schedule
        when should it appear
        when should it go away
        how long has the mm been running when it happens.
        did u check for any issue on the module github page
        did u check for any updates?
        • N
          Nneuland @sdetweil
          I’m not certain when exactly this is happening. I’m finding that one of the trains in the module disappears and comes back on it’s own.
          Always seems to be long enough to notice it for a few days though.
          It should always be visible, as long as there isn’t a cut in the service. Which there currently is not.
          MM is always on. Although I’ve tried restarts to correct the issue
          I have not seen any update on the github module page, and I am currently up to date.
          I’m more looking to see if anyone using the NYC_Transit module has had any of the same issues.
          Nick
