Paul's frameless MM- finally done :)
@PaulB ah that’s unfortunate. The mirror still looks awsome! And it’s not that bad if you only see it in certain conditions
@PaulB Wow that is one aesthetic mirror - the frameless look is great
I was looking to model mine on Bangee’s mirror as well, but got turned off by the cost. How did you attach the frame to the mirror? And what kind of wood and other parts did you use in the frame?
Cheers from Claremont, California
Dear @jchan,
the mirror is attached through 4 screws which I drilled through the glas. (make sure that you tape before drilling otherwise the glas will break).The wood is just plain wood from the local shop.
