    Paul's frameless MM- finally done :)
    13 Posts 6 Posters 11.9k Views 6 Watching
      PaulB
      Dear guys,
      I am finally done with my first MM2- project.
      Thank you very much for your great support and ideas to finish this project.
      There are only a few things left to work on:
      • fix some errors with the DHT22-sensor
      • find a GitHub module which shows the whole month with every iCal-entry. Also find the right positioning for it. I would like to position it in the Top/middle space (not top_bar, Ive tried it already :D ).
      • enable wifi-connection. This hunts me since several months :D I still have no clue where the error is and how to fix it.
      • find a Github module which enables me to send push -up notifications to the mirror. e.g. a friend goes into my room, looks a the running mirror and the mirror says something like "Hello XY, my name is Henry. It’s nice to meet you, you fag :D )
      Best regards, Paul
      You will find attached to this topic a few pictures.
      1 Reply Last reply Reply Quote 4
        PaulB
        Here is the final positioning :)
        schlachtkreuzer6S J 2 Replies Last reply Reply Quote 3
        • tosti007T Offline
          tosti007 Module Developer
          Looks awsome! Great job and a good first mirror :thumbsup_tone1:
          If there is anything don't hesitate to contact me!
          ProfileSwitcher, TouchNotifications
          • yawnsY Offline
            yawns Moderator
            Nice, I like the frameless design. I am up to something similar.
            • schlachtkreuzer6S Offline
              schlachtkreuzer6 @PaulB
              @PaulB WoW nice work! :) i like the frameless thing! somehow it looks broken in the left bottom corner!? or is it just an illusion?
              lolobyteL 1 Reply Last reply Reply Quote 0
              • lolobyteL Offline
                lolobyte @schlachtkreuzer6
                @schlachtkreuzer6
                That’s realy shitty. I mean both corner are broken on the lower side.
                schlachtkreuzer6S 1 Reply Last reply Reply Quote 0
                  schlachtkreuzer6 @lolobyte
                  @lolobyte Awehh Damn! May bad, how is it happend?
                    PaulB @schlachtkreuzer6
                    @schlachtkreuzer6
                    Yeah I know. It fell down on the front. After that I installed two “holders” for the frame. Now, it should not ever happen again. I guess you can feel my pain as I saw it. Nevertheless it still looks pretty cool and the broken corners are only visible if you stand right next to them or the sunlight shines on them.
                    tosti007T 1 Reply Last reply Reply Quote 0
                    • tosti007T Offline
                      tosti007 Module Developer @PaulB
                      @PaulB Wouldn’t it be possible to glue them or something simmilair so that you don’t see the cracks at all anymore and for better stability? (No idea if it’s possible with mirrors, just a thought)
                        PaulB @tosti007
                        @tosti007 Thought the same and contacted the manufacturer. Unfortunatly they said it is not possible to enhance the stability with a super glue or something similar.
                        The positive point is that the mirror does not stand on the mirror. It stand in the frame. Therefore it should be ok, hopefully.
                        • tosti007T Offline
                          @PaulB ah that’s unfortunate. The mirror still looks awsome! And it’s not that bad if you only see it in certain conditions
                            jchan @PaulB
                            @PaulB Wow that is one aesthetic mirror - the frameless look is great :grinning:
                            I was looking to model mine on Bangee’s mirror as well, but got turned off by the cost. How did you attach the frame to the mirror? And what kind of wood and other parts did you use in the frame?
                            Cheers from Claremont, California
                              PaulB
                              Dear @jchan,
                              the mirror is attached through 4 screws which I drilled through the glas. (make sure that you tape before drilling otherwise the glas will break).
                              The wood is just plain wood from the local shop.
