    v2.16.0
    Scheduled Pinned Locked Moved MagicMirror
    1 Posts 1 Posters 11.2k Views 1 Watching
    • MichMichM Offline
      MichMich
      [2.16.0] - 2021-07-01
      https://github.com/MichMich/MagicMirror/releases/tag/v2.16.0
      Special thanks to the following contributors: @210954, @B1gG, @codac, @Crazylegstoo, @daniel, @earlman, @ezeholz, @FrancoisRmn, @jupadin, @khassel, @KristjanESPERANTO, @njwilliams, @oemel09, @r3wald, @rejas, @rico24, Faizan Ahmed.
      Added
      • Added French translations for “MODULE_CONFIG_ERROR” and “PRECIP”.
      • Added German translation for “PRECIP”.
      • Added Dutch translation for “WEEK”, “PRECIP”, “MODULE_CONFIG_CHANGED” and “MODULE_CONFIG_ERROR”.
      • Added first test for Alert module.
      • Added support for dateFormat when not using timeFormat: "absolute".
      • Added custom-properties for colors and fonts for improved styling experience, see custom.css.sample file.
      • Added custom-properties for gaps around body and between modules.
      • Added test case for recurring calendar events.
      • Added new Environment Canada provider for default WEATHER module (weather data for Canadian locations only).
      • Added list view for newsfeed module.
      • Added dev dependency jest, switching from mocha to jest.
      Updated
      • Bump node-ical to v0.13.0 (now last runtime dependency using deprecated request package is removed).
      • Use codecov in informational mode.
      • Refactor code into es6 where possible (e.g. var -> let/const).
      • Use node v16 in github workflow (replacing node v10).
      • Moved some files into better suited directories.
      • Update dependencies in package.json, require node >= v12, remove rrule-alt and rrule.
      • Update dependencies in package.json and migrate husky to v6, fix husky setup in prod environment.
      • Cleaned up error handling in newsfeed and calendar modules for real.
      • Updated default WEATHER module such that a provider can optionally set a custom unit-of-measure for precipitation (weatherObject.precipitationUnits).
      • Update documentation.
      • Update jest tests: Reset changes on js/logger.js, mock logger.js in global_vars tests.
      • Update dependencies in package.json.
      Removed
      • Switching from mocha to jest so removed following dev dependencies: chai, chai-as-promised, mocha, mocha-each, mocha-logger.
      Fixed
      • Fix calendar start function logging inconsistency.
      • Fix updatenotification start function logging inconsistency.
      • Checks and applies the showDescription setting for the newsfeed module again.
      • Fix issue with openweathermap not showing current or forecast info when using onecall API.
      • Fix tests in weather module and add one for decimalPoint in forecast.
      • Fix decimalSymbol in the forecast part of the new weather module (#2530).
      • Fix wrong treatment of appendLocationNameToHeader when using ukmetofficedatahub.
      • Fix alert not recognizing multiple alerts (#2522).
      • Fix fetch option httpsAgent to agent in calendar module (#466).
      • Fix module updatenotification which did not work for repos with many refs (#1907).
      • Fix config check failing when encountering let syntax (“Parsing error: Unexpected token config”).
      • Fix calendar debug check.
      • Really run prettier over all files.
      • Fix logger.js after jest changes, use --forceExit running jest.
      • Workaround for dev_console test using getWindowCount.
      • MichMichM MichMich locked this topic on
