    Use the Raspberry PI for MagicMirror and as NAS (OpenMediaVault) simultaneously
    2 Posts 3 Posters 1.1k Views 3 Watching
    • janoschvkJ
      janoschvk
      Hello,
      I’ve set up my MagicMirror a while ago. Now I came across this possibility to use the Raspberry Pi as NAS (Network Attached Storage). But in all tutorials (for the NAS program openmediavault), it’s said that I need to flash the openMediaVault.iso to my micro SD card. By that, my Raspberry Pi’s MagicMirror System would stop working right ?
      Now I’ve seen this other way of installing a NAS program to the pi: https://ittweak.de/raspberry-pi-nas-server-datei-server-einrichten-mit-samba/ (using samba and without a need for SD cards).
      Now I thought it might be a good idea of asking before. Is it possible to use the pi as NAS and magicmirror simlutaneously ? Has anybody made experiences with something like that ?
      I’m thankful for any advice!
      Best Regards,
      Janosch
      • M
        matt216
        It is definitely possible to run multiple services on the same pi, as long as the pi is powerful enough.
        You mentioned the NAS software has its own .iso - if you used that you’d then have to install magicmirror on top. You may come in to some conflicts there and have to tweak, but definitely worth a shot.
        Or if you start with your magicmirror install it is fairly simple to expose a shared folder to the network and have the pi act as a NAS also.
        Good luck!
