    MMM-CalendarExt the mirror knocks me down?
    16 Posts 3 Posters 6.1k Views 3 Watching
    • C Offline
      chrixbrown @DJBOOB66
      @djboob66 and when I edit I always use the visual studio code editor and I also use the raspi editor
        sdetweil @chrixbrown
        @chrixbrown can u look at the messages where u start MM
        npm start
        or
        pm2
        if pm2, then the command
        pm2 logs --lines=100
        will show you the output
        if U need to minimize the MM screen, alt-spacebar-n will do that (same as on Windows)
          DJBOOB66 @chrixbrown
          @chrixbrown
          I am doing my configurations in virtual box and if I have everything correct I do not know why it gives me that error.
          So the magic mirror is not running on a pi but a pc runing virtual box with pi OS??
            sdetweil @DJBOOB66
            @djboob66 i install on a PI OS x86 under VMware to test, so it should work…
            I don’t think the VM has anything to do with it…
            this is one of the MM modules that is missing some required libraries that were removed in 2.16
            valid-url
            rrule-alt
            and request
            the startup messages for MM should say
            module not found
            and then MM doesn’t start
            • C Offline
              chrixbrown @sdetweil
              @sdetweil to already this module no longer works?
                @chrixbrown no. u need to look at the messages so we can figure out what to do
