    MMM-CalendarExt the mirror knocks me down?
    16 Posts 3 Posters 12.7k Views 3 Watching
      chrixbrown @sdetweil
      @sdetweil is that the module does not load me it knocks down the mirror, but I delete the module from config and reload my modules normally but I put the MMM-CalendarExt and it does not load my mirror
      C 1 Reply Last reply
        chrixbrown @chrixbrown
        @chrixbrown c35688fe-8c36-47a8-a0e8-f4397a974a6a-image.png this is how it gets me with the module
        79a77e4b-0ff8-4b7c-b283-3c5519cacc2d-image.png and without the module
          DJBOOB66
          @chrixbrown said in MMM-CalendarExt the mirror knocks me down?:
          @chrixbrown
          So you do have VNC on your PC as well?
          you have added configs to the config.js file???
          And MMM-CalendarExt will not load on your mirror just keeps saying LOADING is this the case?
          Have you added your details to CalendarExt?
          Can you post your config here?
          have you connected Pi OS to the internet???
          C 3 Replies Last reply
            chrixbrown @DJBOOB66
            @djboob66 I am doing my configurations in virtual box and if I have everything correct I do not know why it gives me that error.
            let config = {
            	address: "0.0.0.0",	// default is "localhost"
            	port: 8080,
            	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
            	ipWhitelist: [], 	// Set [] to allow all IP addresses
            	language: "en",
            	locale: "en-US",
            	timeFormat: 24,
            	units: "metric",
                module: 'MMM-Remote-Control',
                // position: 'bottom_left',
                    customCommand: {
            			        shutdownCommand: 'shell command to shutdown your pc',
                    rebootCommand: 'shell command to reboot your pc',
                    monitorOnCommand: 'shell command to turn on your monitor',
                    monitorOffCommand: 'shell command to turn off your monitor',
                    monitorStatusCommand: 'shell command to return status of monitor, must return either "HDMI" or "true" if screen is on; or "TV is Off" or "false" if it is off to be recognized'
            		},  // Optional, See "Using Custom Commands" below
                    showModuleApiMenu: true, // Optional, Enable the Module Controls menu
                    secureEndpoints: true, // Optional, See API/README.md
                    customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
                    apiKey: "bc2e979db92f4741afad01d5d18eb8e2", // Optional, See API/README.md for details
                    classes: {
            			"Any Name You Want": {
                        hide: ["calendar"],
                        show: ["newsfeed"],
                        toggle: ["clock"],
                    "Another Name You Want": {
                        hide: ["newsfeed"],
                        show: ["calendar"],
            		} // Optional, See "Custom Classes" below
            			module: "alert",
            		module: "clock",
            		position: "top_left",	// This can be any of the regions.
            			displaySeconds: "true",
            			displayType: "both", //digital, analog, or both}
            			clockBold: "true"
            			header: "US Holidays",
            						symbol: "calendar-check",
            						url: "https://calendar.google.com/calendar/ical/trabajoonline043%40gmail.com/public/basic.ics"					}
            			module: "weather",
            				type: "current",
            				locationID: "5695604",
            				apiKey: "220ba692d61b02e41ea809571c2ff06e"
            			module: "weather",
            			header: "Weather Forecast",
            				type: "forecast",
              module: "MMM-OpenWeatherMapForecast",
              header: "Weather",
              classes: "default everyone",
              disabled: false,
                apikey: "220ba692d61b02e41ea809571c2ff06e",
                latitude: "41.821541",
                longitude: "-103.661751",
                iconset: "4c",
                concise: false,
                forecastLayout: "tiled"
            			module: "newsfeed",
            			position: "bottom_bar",
            				feeds: [
            						title: "JW",
            						url: "https://www.jw.org/es/noticias/testigos-de-jehova/rss/NewsSubsectionRSSFeed/feed.xml"
            				showSourceTitle: true,
            				showPublishDate: true,
            				broadcastNewsFeeds: true,
            				broadcastNewsUpdates: true
                module: "MMM-Wallpaper",
                position: "fullscreen_below",
                config: { // See "Configuration options" for more information.
                  source: "bing",
                  slideInterval: 60 * 1000 // Change slides every minute
                  module: 'MMM-CalendarExt',
                  position: "top_center",
                    system: {
                      show: ["Holidays", "upcoming"],
                      locale: 'en',
                      redrawInterval:60000,
                    views: {
                      Holidays: {
                        position:'bottom_bar',
                        counts:7,
                      upcoming: {
                        position:'top_left',
                        limit:5
                    defaultCalendar: {
                      maxEntries:50,
                      maxDays:180,
                      interval: 1000*60*5,
                    calendars :[
                        symbol: "calendar-o",
                        styleName: "style1",
            and I do as the guide says to extract the git
            cd ~ / MagicMirror / modules
            git clone https://github.com/eouia/MMM-CalendarExt.git
            and I do all the steps of the installer.
              @djboob66 and this is all correct it is at the moment I put the module in my configuration it makes me as if I did not have internet and when I do it it puts my normal magic mirror again
                @djboob66 and when I edit I always use the visual studio code editor and I also use the raspi editor
                D 1 Reply Last reply
                  sdetweil @chrixbrown
                  @chrixbrown can u look at the messages where u start MM
                  npm start
                  or
                  pm2
                  if pm2, then the command
                  pm2 logs --lines=100
                  will show you the output
                  if U need to minimize the MM screen, alt-spacebar-n will do that (same as on Windows)
                    DJBOOB66 @chrixbrown
                    @chrixbrown
                    So the magic mirror is not running on a pi but a pc runing virtual box with pi OS??
                      sdetweil @DJBOOB66
                      @djboob66 i install on a PI OS x86 under VMware to test, so it should work…
                      I don’t think the VM has anything to do with it…
                      this is one of the MM modules that is missing some required libraries that were removed in 2.16
                      valid-url
                      rrule-alt
                      and request
                      the startup messages for MM should say
                      module not found
                      and then MM doesn’t start
                        @sdetweil to already this module no longer works?
                          @chrixbrown no. u need to look at the messages so we can figure out what to do
