    MMM-CalendarExt the mirror knocks me down?
    16 Posts 3 Posters 6.2k Views 3 Watching
      chrixbrown @DJBOOB66
      @djboob66 I’m using anyDesk to control it remotely, but when I configure the calendar module, I get it, I remove it and my mirror comes out again.but I already installed the program that you told me
        DJBOOB66
        You will need to enable VNC on Pi as well it already installed on Pi
        Preferences
        Raspberry Pi Configuration
        Interfaces tab
        Enabled VNC
        once up and running can you do a snippet of your config for us.
        type snipping in windows search box
          and if you config your mm with
          address:"0.0.0.0",
          ipWhitelist:[],
          then u can use your PC browser to look at and debug, without vnc, or whatever
            chrixbrown @sdetweil
            @sdetweil is that the module does not load me it knocks down the mirror, but I delete the module from config and reload my modules normally but I put the MMM-CalendarExt and it does not load my mirror
              chrixbrown @chrixbrown
              @chrixbrown c35688fe-8c36-47a8-a0e8-f4397a974a6a-image.png this is how it gets me with the module
              79a77e4b-0ff8-4b7c-b283-3c5519cacc2d-image.png and without the module
                DJBOOB66
                @chrixbrown said in MMM-CalendarExt the mirror knocks me down?:
                @chrixbrown
                So you do have VNC on your PC as well?
                you have added configs to the config.js file???
                And MMM-CalendarExt will not load on your mirror just keeps saying LOADING is this the case?
                Have you added your details to CalendarExt?
                Can you post your config here?
                have you connected Pi OS to the internet???
                C 3 Replies Last reply Reply Quote 0
                  @djboob66 I am doing my configurations in virtual box and if I have everything correct I do not know why it gives me that error.
                  let config = {
                  	address: "0.0.0.0",	// default is "localhost"
                  	port: 8080,
                  	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
                  	ipWhitelist: [], 	// Set [] to allow all IP addresses
                  	language: "en",
                  	locale: "en-US",
                  	timeFormat: 24,
                  	units: "metric",
                      module: 'MMM-Remote-Control',
                      // position: 'bottom_left',
                          customCommand: {
                  			        shutdownCommand: 'shell command to shutdown your pc',
                          rebootCommand: 'shell command to reboot your pc',
                          monitorOnCommand: 'shell command to turn on your monitor',
                          monitorOffCommand: 'shell command to turn off your monitor',
                          monitorStatusCommand: 'shell command to return status of monitor, must return either "HDMI" or "true" if screen is on; or "TV is Off" or "false" if it is off to be recognized'
                  		},  // Optional, See "Using Custom Commands" below
                          showModuleApiMenu: true, // Optional, Enable the Module Controls menu
                          secureEndpoints: true, // Optional, See API/README.md
                          customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
                          apiKey: "bc2e979db92f4741afad01d5d18eb8e2", // Optional, See API/README.md for details
                          classes: {
                  			"Any Name You Want": {
                              hide: ["calendar"],
                              show: ["newsfeed"],
                              toggle: ["clock"],
                          "Another Name You Want": {
                              hide: ["newsfeed"],
                              show: ["calendar"],
                  		} // Optional, See "Custom Classes" below
                  			module: "alert",
                  		module: "clock",
                  		position: "top_left",	// This can be any of the regions.
                  			displaySeconds: "true",
                  			displayType: "both", //digital, analog, or both}
                  			clockBold: "true"
                  			header: "US Holidays",
                  						symbol: "calendar-check",
                  						url: "https://calendar.google.com/calendar/ical/trabajoonline043%40gmail.com/public/basic.ics"					}
                  			module: "weather",
                  				type: "current",
                  				locationID: "5695604",
                  				apiKey: "220ba692d61b02e41ea809571c2ff06e"
                  			module: "weather",
                  			header: "Weather Forecast",
                  				type: "forecast",
                    module: "MMM-OpenWeatherMapForecast",
                    header: "Weather",
                    classes: "default everyone",
                    disabled: false,
                      apikey: "220ba692d61b02e41ea809571c2ff06e",
                      latitude: "41.821541",
                      longitude: "-103.661751",
                      iconset: "4c",
                      concise: false,
                      forecastLayout: "tiled"
                  			module: "newsfeed",
                  			position: "bottom_bar",
                  				feeds: [
                  						title: "JW",
                  						url: "https://www.jw.org/es/noticias/testigos-de-jehova/rss/NewsSubsectionRSSFeed/feed.xml"
                  				showSourceTitle: true,
                  				showPublishDate: true,
                  				broadcastNewsFeeds: true,
                  				broadcastNewsUpdates: true
                      module: "MMM-Wallpaper",
                      position: "fullscreen_below",
                      config: { // See "Configuration options" for more information.
                        source: "bing",
                        slideInterval: 60 * 1000 // Change slides every minute
                        module: 'MMM-CalendarExt',
                        position: "top_center",
                          system: {
                            show: ["Holidays", "upcoming"],
                            locale: 'en',
                            redrawInterval:60000,
                          views: {
                            Holidays: {
                              position:'bottom_bar',
                              counts:7,
                            upcoming: {
                              position:'top_left',
                              limit:5
                          defaultCalendar: {
                            maxEntries:50,
                            maxDays:180,
                            interval: 1000*60*5,
                          calendars :[
                              symbol: "calendar-o",
                              styleName: "style1",
                  and I do as the guide says to extract the git
                  cd ~ / MagicMirror / modules
                  git clone https://github.com/eouia/MMM-CalendarExt.git
                  and I do all the steps of the installer.
                    @djboob66 and this is all correct it is at the moment I put the module in my configuration it makes me as if I did not have internet and when I do it it puts my normal magic mirror again
                      @djboob66 and when I edit I always use the visual studio code editor and I also use the raspi editor
                        sdetweil @chrixbrown
                        @chrixbrown can u look at the messages where u start MM
                        npm start
                        or
                        pm2
                        if pm2, then the command
                        pm2 logs --lines=100
                        will show you the output
                        if U need to minimize the MM screen, alt-spacebar-n will do that (same as on Windows)
