OpenWeatherMap showing UTC time (not sunset) instead of CEST
I have a problem that I first saw with MMM-RAIN-MAP and using the open weather map API, the forecast clock was always two hours behind. Now with updating Weather module from weather forecast, I see the same behaviour in hourly forecast. Has anyone seen this?
The date command returns the correct time & date in the console.
/* Magic Mirror Config Sample * * By Michael Teeuw https://michaelteeuw.nl * MIT Licensed. * * For more information on how you can configure this file * See https://github.com/MichMich/MagicMirror#configuration * */ let config = { address: "localhost", // Address to listen on, can be: // - "localhost", "127.0.0.1", "::1" to listen on loopback interface // - another specific IPv4/6 to listen on a specific interface // - "0.0.0.0", "::" to listen on any interface // Default, when address config is left out or empty, is "localhost" port: 8080, basePath: "/", // The URL path where MagicMirror is hosted. If you are using a Reverse proxy // you must set the sub path here. basePath must end with a / ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.0.0/16"], // Set [] to allow all IP addresses // or add a specific IPv4 of 192.168.1.5 : // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.5"], // or IPv4 range of 192.168.3.0 --> 192.168.3.15 use CIDR format : // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.3.0/28"], useHttps: false, // Support HTTPS or not, default "false" will use HTTP httpsPrivateKey: "", // HTTPS private key path, only require when useHttps is true httpsCertificate: "", // HTTPS Certificate path, only require when useHttps is true language: "de", logLevel: ["INFO", "LOG", "WARN", "ERROR"], timeFormat: 24, units: "metric", // serverOnly: true/false/"local" , // local for armv6l processors, default // starts serveronly and then starts chrome browser // false, default for all NON-armv6l devices // true, force serveronly mode, because you want to.. no UI on this device modules: [ { module: "alert", }, { module: "updatenotification", position: "top_bar" }, { module: "clock", position: "top_left" }, { module: "MMM-RAIN-MAP", position: "center", config: { animationSpeed: 1800, backgroundColor: "rgba(0, 0, 0, 0)", displayClockSymbol: false, displayTime: true, extraDelayLastFrame: 2000, height: "350px", key: "-", map: "OSM", mapTypeId: "terrain", lat: 52.777777, lng: 13.777777, markers: [ { lat: 52.222, lng: 13.222, color: "red" } ], onlyOnRain: false, opacity: 0.65, timeFormat: 24, updateIntervalInSeconds: 300, width: "450px", zoom: 11, zoomOutEach: 0, zoomOutLevel: 2, osmMapUrl: "https://cartodb-basemaps-{s}.global.ssl.fastly.net/dark_all/{z}/{x}/{y}.png" } }, { module: "weather", position: "top_right", config: { type: "current", location: "Spandau", locationID: "7290252", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city apiKey: "-", roundTemp: true, showIndoorTemperature: true, animationSpeed: 1000 } }, { module: "weather", position: "top_right", config: { type: "hourly", weatherEndpoint: '/onecall', lat: 52.5, lon: 13.2, apiKey: "-", roundTemp: true, animationSpeed: 1000, appendLocationNameToHeader: false } }, { module: "weather", position: "top_right", header: "Vorschau", config: { type: "daily", tableclass: "medium", location: "Spandau", locationID: "7290252", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city apiKey: "-", roundTemp: true, // ignoreToday: true } }, ] }; /*************** DO NOT EDIT THE LINE BELOW ***************/ if (typeof module !== "undefined") {module.exports = config;} -
@oneartur i don’t know. but what timezone is the MM running on?
Hi @oneartur,
please be aware, that MMM-RAIN-MAP’s radar layers are history data from -2h until now (no forecast!) ;-) -
@jalibu
Ohhh… that is interesting! So I guess it’s expected behavior then.Do you happen to know where and how I could get forecasts?
@oneartur unfortunately no.
The module uses rainviewer.com API. The free plan only offers history data.I started to play around with windy.com and had good results on my MacBook for development, but windy’s map rendering is so heavy weight, that it did not really work stable on the raspberry pi.
I also find it a pity, that MMM-RAIN-MAP does not provide a forcast. Let me know, if you find a free dataprovider to enhance that.
