    Cursor shown in v2.16.0
    18 Posts 4 Posters 5.0k Views 4 Watching
    • karsten13K Offline
      karsten13 @MajorC
      @majorc said in Cursor shown in v2.16.0:
      Or do I have to wait for version 17?
      In v2.16.0 we have electron v11, in current develop branch (which will become v2.17.0 in October) we have upgraded to electron v13.
        sdetweil @karsten13
        @karsten13 @MajorC
        so u can try develop, but there is no guarantee that is is fixed there
        karsten13K 1 Reply Last reply Reply Quote 1
          karsten13 @sdetweil
          could fix the black cursor with an entry in custom.css:
          html {
            cursor: none !important;
          Can you test if this works on your side? If so we should change this in main.css (will provide a PR then).
            MajorC Project Sponsor @karsten13
            @karsten13 said in Cursor shown in v2.16.0:
            Hi Kasten,
            I tried !important in the custom.css and in the main.css. The cursor is still visible.
            Even after after a reboot of the pi, the same, still visible.
            I think I will wait for v2.17.0 in October.
            karsten13K 2 Replies Last reply Reply Quote 0
              karsten13 @MajorC
              @majorc
              tried yesterday on my pi3:
              • v2.16.0: no cursor
              • v2.17.0-develop: black cursor
              • v2.17.0-develop with css cursor: none !important;: no cursor
              So waiting on v2.17.0 is no solution.
              Another idea is to simulate a cursor movement on electron start.
                karsten13 @MajorC
                @majorc
                can you try to patch the file js/electron.js for a test, please add the following at line 74:
                	mainWindow.webContents.on('dom-ready', (event)=> {
                		mainWindow.webContents.sendInputEvent({type: "mouseMove", x: 0, y: 0});
                Does this hide the black cursor?
                (I changed the code here again …)
                  Like so?
                  // Open the DevTools if run with "npm start dev"
                  	if (process.argv.includes("dev")) {
                  		if (process.env.JEST_WORKER_ID !== undefined) {
                  			// if we are running with jest
                  			var devtools = new BrowserWindow(electronOptions);
                  			mainWindow.webContents.setDevToolsWebContents(devtools.webContents);
                  		mainWindow.webContents.openDevTools();
                  	// Set responders for window events.
                  	mainWindow.on("closed", function () {
                  		mainWindow = null;
                  That works perfekt! Thank you so much!
                    karsten13 @MajorC
                    @majorc o.k., then I will provide a PR for this in the mm repo
