    Cursor shown in v2.16.0
    18 Posts 4 Posters 6.6k Views 4 Watching
      MajorC Project Sponsor @MajorC
      Fun fact, if I move the the mouse, the cursor disappears immediately.
        sdetweil @MajorC
        @majorc so, it sounds like a defect in the electron version in 2.16
          MajorC Project Sponsor @sdetweil
          @sdetweil I do not know what that mean. Is there a way that I can fix it?
          Or do I have to wait for version 17?
          S karsten13K 2 Replies Last reply Reply Quote 0
            sdetweil @MajorC
            @majorc if u use chrome do u see the cursor
            my prior comment was that maybe WE don’t have a solution
              @sdetweil I see the cursor only on the pi. And it disappears if I move the mouse the first time on the pi. But the cursor is visible again after i do a
              pm2 restart 0
              On my windows machine witch chrome, I don’t see the cursor at no time.
                sdetweil @MajorC
                @majorc so, that confirms it’s an electron issue.
                you could change to run server mode with chrome on the pi.
                • karsten13K
                  karsten13 @MajorC
                  @majorc said in Cursor shown in v2.16.0:
                  In v2.16.0 we have electron v11, in current develop branch (which will become v2.17.0 in October) we have upgraded to electron v13.
                    sdetweil @karsten13
                    @karsten13 @MajorC
                    so u can try develop, but there is no guarantee that is is fixed there
                    karsten13K 1 Reply Last reply Reply Quote 1
                    • karsten13K
                      karsten13 @sdetweil
                      could fix the black cursor with an entry in custom.css:
                      html {
                        cursor: none !important;
                      Can you test if this works on your side? If so we should change this in main.css (will provide a PR then).
                        MajorC Project Sponsor @karsten13
                        @karsten13 said in Cursor shown in v2.16.0:
                        Hi Kasten,
                        I tried !important in the custom.css and in the main.css. The cursor is still visible.
                        Even after after a reboot of the pi, the same, still visible.
                        I think I will wait for v2.17.0 in October.
                        • karsten13K
                          karsten13 @MajorC
                          @majorc
                          tried yesterday on my pi3:
                          • v2.16.0: no cursor
                          • v2.17.0-develop: black cursor
                          • v2.17.0-develop with css cursor: none !important;: no cursor
                          So waiting on v2.17.0 is no solution.
                          Another idea is to simulate a cursor movement on electron start.
                          • karsten13K
                            karsten13 @MajorC
                            @majorc
                            can you try to patch the file js/electron.js for a test, please add the following at line 74:
                            	mainWindow.webContents.on('dom-ready', (event)=> {
                            		mainWindow.webContents.sendInputEvent({type: "mouseMove", x: 0, y: 0});
                            Does this hide the black cursor?
                            (I changed the code here again …)
                              Like so?
                              // Open the DevTools if run with "npm start dev"
                              	if (process.argv.includes("dev")) {
                              		if (process.env.JEST_WORKER_ID !== undefined) {
                              			// if we are running with jest
                              			var devtools = new BrowserWindow(electronOptions);
                              			mainWindow.webContents.setDevToolsWebContents(devtools.webContents);
                              		mainWindow.webContents.openDevTools();
                              	// Set responders for window events.
                              	mainWindow.on("closed", function () {
                              		mainWindow = null;
                              That works perfekt! Thank you so much!
                              • karsten13K
                                karsten13 @MajorC
                                @majorc o.k., then I will provide a PR for this in the mm repo
