    Cursor shown in v2.16.0
    18 Posts 4 Posters 6.6k Views 4 Watching
      sdetweil @MajorC
      @majorc if u use chrome do u see the cursor
      my prior comment was that maybe WE don’t have a solution
        MajorC Project Sponsor @sdetweil
        @sdetweil I see the cursor only on the pi. And it disappears if I move the mouse the first time on the pi. But the cursor is visible again after i do a
        pm2 restart 0
        On my windows machine witch chrome, I don’t see the cursor at no time.
          sdetweil @MajorC
          @majorc so, that confirms it’s an electron issue.
          you could change to run server mode with chrome on the pi.
          • karsten13K
            karsten13 @MajorC
            @majorc said in Cursor shown in v2.16.0:
            Or do I have to wait for version 17?
            In v2.16.0 we have electron v11, in current develop branch (which will become v2.17.0 in October) we have upgraded to electron v13.
              sdetweil @karsten13
              @karsten13 @MajorC
              so u can try develop, but there is no guarantee that is is fixed there
              karsten13K 1 Reply Last reply Reply Quote 1
              • karsten13K
                karsten13 @sdetweil
                could fix the black cursor with an entry in custom.css:
                html {
                  cursor: none !important;
                Can you test if this works on your side? If so we should change this in main.css (will provide a PR then).
                  MajorC Project Sponsor @karsten13
                  @karsten13 said in Cursor shown in v2.16.0:
                  Hi Kasten,
                  I tried !important in the custom.css and in the main.css. The cursor is still visible.
                  Even after after a reboot of the pi, the same, still visible.
                  I think I will wait for v2.17.0 in October.
                  karsten13K 2 Replies Last reply Reply Quote 0
                  • karsten13K
                    karsten13 @MajorC
                    @majorc
                    tried yesterday on my pi3:
                    • v2.16.0: no cursor
                    • v2.17.0-develop: black cursor
                    • v2.17.0-develop with css cursor: none !important;: no cursor
                    So waiting on v2.17.0 is no solution.
                    Another idea is to simulate a cursor movement on electron start.
                    • karsten13K
                      karsten13 @MajorC
                      @majorc
                      can you try to patch the file js/electron.js for a test, please add the following at line 74:
                      	mainWindow.webContents.on('dom-ready', (event)=> {
                      		mainWindow.webContents.sendInputEvent({type: "mouseMove", x: 0, y: 0});
                      Does this hide the black cursor?
                      (I changed the code here again …)
                        Like so?
                        // Open the DevTools if run with "npm start dev"
                        	if (process.argv.includes("dev")) {
                        		if (process.env.JEST_WORKER_ID !== undefined) {
                        			// if we are running with jest
                        			var devtools = new BrowserWindow(electronOptions);
                        			mainWindow.webContents.setDevToolsWebContents(devtools.webContents);
                        		mainWindow.webContents.openDevTools();
                        	// Set responders for window events.
                        	mainWindow.on("closed", function () {
                        		mainWindow = null;
                        That works perfekt! Thank you so much!
                        • karsten13K
                          karsten13 @MajorC
                          @majorc o.k., then I will provide a PR for this in the mm repo
