    Cursor shown in v2.16.0
    18 Posts 4 Posters 6.6k Views 4 Watching
      MajorC Project Sponsor @sdetweil
      @sdetweil as it was working fine before, I am not 100% happy to just install something over.
        MajorC Project Sponsor @MajorC
        Fun fact, if I move the the mouse, the cursor disappears immediately.
          sdetweil @MajorC
          @majorc so, it sounds like a defect in the electron version in 2.16
            @sdetweil I do not know what that mean. Is there a way that I can fix it?
            Or do I have to wait for version 17?
            S karsten13K 2 Replies Last reply Reply Quote 0
              sdetweil @MajorC
              @majorc if u use chrome do u see the cursor
              my prior comment was that maybe WE don’t have a solution
                @sdetweil I see the cursor only on the pi. And it disappears if I move the mouse the first time on the pi. But the cursor is visible again after i do a
                pm2 restart 0
                On my windows machine witch chrome, I don’t see the cursor at no time.
                  sdetweil @MajorC
                  @majorc so, that confirms it’s an electron issue.
                  you could change to run server mode with chrome on the pi.
                  • karsten13K
                    karsten13 @MajorC
                    @majorc said in Cursor shown in v2.16.0:
                    In v2.16.0 we have electron v11, in current develop branch (which will become v2.17.0 in October) we have upgraded to electron v13.
                      sdetweil @karsten13
                      @karsten13 @MajorC
                      so u can try develop, but there is no guarantee that is is fixed there
                      karsten13K 1 Reply Last reply Reply Quote 1
                      • karsten13K
                        karsten13 @sdetweil
                        could fix the black cursor with an entry in custom.css:
                        html {
                          cursor: none !important;
                        Can you test if this works on your side? If so we should change this in main.css (will provide a PR then).
                          MajorC Project Sponsor @karsten13
                          @karsten13 said in Cursor shown in v2.16.0:
                          Hi Kasten,
                          I tried !important in the custom.css and in the main.css. The cursor is still visible.
                          Even after after a reboot of the pi, the same, still visible.
                          I think I will wait for v2.17.0 in October.
                          • karsten13K
                            karsten13 @MajorC
                            @majorc
                            tried yesterday on my pi3:
                            • v2.16.0: no cursor
                            • v2.17.0-develop: black cursor
                            • v2.17.0-develop with css cursor: none !important;: no cursor
                            So waiting on v2.17.0 is no solution.
                            Another idea is to simulate a cursor movement on electron start.
                            • karsten13K
                              karsten13 @MajorC
                              @majorc
                              can you try to patch the file js/electron.js for a test, please add the following at line 74:
                              	mainWindow.webContents.on('dom-ready', (event)=> {
                              		mainWindow.webContents.sendInputEvent({type: "mouseMove", x: 0, y: 0});
                              Does this hide the black cursor?
                              (I changed the code here again …)
                                Like so?
                                // Open the DevTools if run with "npm start dev"
                                	if (process.argv.includes("dev")) {
                                		if (process.env.JEST_WORKER_ID !== undefined) {
                                			// if we are running with jest
                                			var devtools = new BrowserWindow(electronOptions);
                                			mainWindow.webContents.setDevToolsWebContents(devtools.webContents);
                                		mainWindow.webContents.openDevTools();
                                	// Set responders for window events.
                                	mainWindow.on("closed", function () {
                                		mainWindow = null;
                                That works perfekt! Thank you so much!
                                • karsten13K
                                  karsten13 @MajorC
                                  @majorc o.k., then I will provide a PR for this in the mm repo
