    MMM-SweepClock
    4 Posts 3 Posters 1.3k Views 4 Watching
    • mumblebajM
      mumblebaj Module Developer
      Created a module based on a classic railway clock using code from manuelmeister
      Installation
      cd ~/MagicMirror/modules/
      git clone https://github.com/mumblebaj/MMM-SweepClock.git
      Add to config.js
      	module: "MMM-SweepClock",
      	position: "top_left", //can use top_right as well or top_center
      Updates
      V1.1.2
      Add timezone feature which allows a user to specify a timezone. This will override the timezone of the system MM is running on.
      Reply Quote 1
        sdetweil @mumblebaj
        @mumblebaj cool…
        I will take it off my list to look at!!
        mumblebajM 1 Reply Last reply
        • mumblebajM
          mumblebaj Module Developer @sdetweil
          @sdetweil No worries. Thanks for the upvote Sam.
          thgmirrorT 1 Reply Last reply
          • thgmirrorT
            thgmirror @mumblebaj
            The webside https://www.timeanddate.com/clocks/free.html
            offers several clocks with a wide range to customize the appearance . A html-code will be generated to integrate it into MM, for example using MMM-SmartWebDisplay.
