    pls help: how to force/refresh "External Compliment File"?
    compliment refresh reloadexternal file
    7 Posts 5 Posters 1.7k Views 5 Watching
      rs
      Hello all,
      I have a remote external file for the Compliment module which works very well, however, when the content of the external file changes the Compliment module doesn’t read the made changes only when restarting the mirror, my question is how to force and reload the external file content to the Compliment module without restarting the mirror?
      Thanks much in advance!
      Ram
        sdetweil @rs
        @rs the default compliments module only reads the file at mm startup.
          rs @sdetweil
          @sdetweil said in pls help: how to force/refresh "External Compliment File"?:
          thank you for your reply!
          well, that’s a bummer…
          swvalentiS R 2 Replies Last reply Reply Quote 0
          • swvalentiS Offline
            swvalenti Project Sponsor @rs
            @rs to jump onto this I can’t get a remote file to work, how did you use yours?
              sdetweil @swvalenti
              @swvalenti see
              sorry, meant this one
              https://forum.magicmirror.builders/topic/6757/need-more-compliments-compliments-json/13?_=1632064035771
              well, both
              https://forum.magicmirror.builders/topic/6757/need-more-compliments-compliments-json/14?_=1632064035783
                rs @rs
                @swvalenti
                			module: "compliments",
                			position: "middle_center",
                				remoteFile: 'https://dl.dropbox.com/s/XXXXXXXXXXXX/mirror_messages.json'	}
                  sdetweil @rs
                  @rs for dropbox u need the shared link ( as no user is logged on to dropbox) and u need dl=1 (instead of 0) to enable direct download
