    Pi 4 B 4GB
    8 Posts 2 Posters 1.2k Views 2 Watching
    • ankonaskiff17A Offline
      ankonaskiff17
      This is a sort of generic question. I have a Pi 4B w/ 4GB ram attached to large screen TV
      When I am actively changing things via config.js, custom.css, terminal open, the Pi really bogs down to point of locking up. I can generally twiddle my fingers for a while and it will come back and I can do some work which will bog it down again.
      If I finish what I am doing, close open windows, reboot, reload MM it runs just fine,
      I don’t see this on PC sized monitors at all.
      Is this due to trying to drive big screen and edit scripts at same time and could I resolve by changing out Pi for 8GB model?
        sdetweil @ankonaskiff17
        @ankonaskiff17 I don’t see this on my 4gb pi4. are u starting mm w pm2?
        my setup tries to register a watcher for config.js changing to restart mm… are u seeing mm stop and start?
        I almost never edit ON pi, I use ssh
        ankonaskiff17A 1 Reply Last reply Reply Quote 0
          ankonaskiff17 @sdetweil
          @sdetweil Using your setup routine. Answer yes to both questions in your setup.
          Primary culprit is when I’m using Developer Tools. Right now with nothing running but mm, MMM-SystemStatsshows about 30% free RAM.
          When I would have VS Code, terminal, Developer Tools running it would get down around 5% free RAM.
          Not sure how MMM-WeatherChart,MMM-SmartWebDisplayand MMM-Jastimpact things since WeatherChart is using Chart.js , Jast has the scrolling ticker and SystemStats has a pretty quick update rate.
            @ankonaskiff17 check for swap space
            free -m
            make the swap space bigger
              @sdetweil That was way easier than sorting out CSS.
              ankonaskiff17A 1 Reply Last reply Reply Quote 1
                ankonaskiff17 @ankonaskiff17
                @sdetweil I may have accidentally stumbled on what is causing the Pi to slog down.
                Increasing the swap helped but definitely didn’t cure.
                In process of troubleshooting a module by using Dev Tools Console, I noticed a different module, and IMO the module CONTENT is generating something called a Vuex Mutatation. I don’t have a clue what that is about other than it appears tied to the National Weather Service link I am using in MMM-SmartWebDesign.
                I saw the line 304 on index.htmlso I pulled up MM’s index.html and it doesn’t even go that high.
                I’ve heard of Chart.js and Moment.js but Vue.js is a new one for me. See attatched image. Any thoughts, suggestions…
                  @ankonaskiff17 Vue is a new programming model. and Vuex is a data persistence library
                  all the Vue stuff runs in the browser, so inside the web display… eats cpu cycles where it runs
                    @sdetweil Anything to be done for it? When I have just MM running all is well .
                    Just seems to be a problem when editing.
                    So that is coming from the origin point of link?
                    It is national radar from NWS and I don’t update it locally in config.js
                    I’ll swag this and guess it generates that Vuex stuff locally when the NWS updates the radar image remotely?
