    MM Config File not matching Dashboard
    10 Posts 2 Posters 1.4k Views 2 Watching
    • D
      droidus
      I have modified the config.js file. But when I log into the desktop, and MM appears, it looks like it is using a default layout, and not my customized one. Do I have to tell it to update, or is it cached somewhere? I’ve tried a reboot, and that didn’t do it.
        sdetweil @droidus
        @droidus if it has an error it falls back to the default
        minimize mm.
        alt-spacebar, n
        open a terminal window,
        ctrl-alt-t
        pm2 stop all
        cd ~/MagicMirror
        npm start >somefile.txt
        wait 15 seconds
        ctrl-c to stop
        nano somefile.txt
        scroll down look for errors
        ctrl-x to exit nano
        • D
          droidus @sdetweil
          > magicmirror@2.16.0 start /home/pi/MagicMirror
          > ./run-start.sh $1
          [29.10.2021 11:04.03.983] [LOG]   Starting MagicMirror: v2.16.0
          [29.10.2021 11:04.03.988] [LOG]   Loading config ...
          [29.10.2021 11:04.03.994] [LOG]   Loading module helpers ...
          [29.10.2021 11:04.03.996] [LOG]   No helper found for module: alert.
          [29.10.2021 11:04.04.163] [LOG]   Initializing new module helper ...
          [29.10.2021 11:04.04.164] [LOG]   Module helper loaded: updatenotification
          [29.10.2021 11:04.04.164] [LOG]   No helper found for module: clock.
          [29.10.2021 11:04.04.345] [LOG]   Initializing new module helper ...
          [29.10.2021 11:04.04.346] [LOG]   Module helper loaded: calendar
          [29.10.2021 11:04.04.346] [LOG]   No helper found for module: compliments.
          [29.10.2021 11:04.04.347] [LOG]   No helper found for module: weather.
          [29.10.2021 11:04.04.372] [LOG]   Initializing new module helper ...
          [29.10.2021 11:04.04.373] [LOG]   Module helper loaded: newsfeed
          [29.10.2021 11:04.04.373] [LOG]   All module helpers loaded.
          [29.10.2021 11:04.04.465] [LOG]   Starting server on port 8080 ...
          [29.10.2021 11:04.04.479] [LOG]   Server started ...
          [29.10.2021 11:04.04.480] [LOG]   Connecting socket for: updatenotification
          [29.10.2021 11:04.04.481] [LOG]   Connecting socket for: calendar
          [29.10.2021 11:04.04.482] [LOG]   Starting node helper for: calendar
          [29.10.2021 11:04.04.482] [LOG]   Connecting socket for: newsfeed
          [29.10.2021 11:04.04.483] [LOG]   Starting node helper for: newsfeed
          [29.10.2021 11:04.04.483] [LOG]   Sockets connected & modules started ...
          [29.10.2021 11:04.04.757] [LOG]   Launching application.
          [29.10.2021 11:04.06.997] [LOG]   Create new calendarfetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
          [29.10.2021 11:04.07.068] [LOG]   Create new newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
          [29.10.2021 11:04.07.534] [INFO]  Calendar-Fetcher: Broadcasting 4 events.
          [29.10.2021 11:04.08.232] [INFO]  Newsfeed-Fetcher: Broadcasting 51 items.
            sdetweil @droidus
            @droidus ok, tell me more
            where is the config.js u modified? should be ~/MagicMirror/config/config.js
            u are running this on raspi OS
            and NOT using MagicMirrorOS, right?
            • D
              droidus @sdetweil
              PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
              NAME="Raspbian GNU/Linux"
              VERSION_ID="10"
              VERSION="10 (buster)"
              VERSION_CODENAME=buster
              ID=raspbian
              ID_LIKE=debian
              HOME_URL="http://www.raspbian.org/"
              SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
              BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
              pi@raspberrypi:~/MagicMirror/config $ ls
              config.js  config.js.sample
                sdetweil @droidus
                @droidus only reason it fails is if some syntax error
                in the mm folder do
                npm run config:check
                • D
                  droidus @sdetweil
                  @sdetweil said in MM Config File not matching Dashboard:
                  > magicmirror@2.16.0 config:check /home/pi/MagicMirror
                  > node js/check_config.js
                  [29.10.2021 11:40.35.104] [INFO]  Checking file...  /home/pi/MagicMirror/config/config.js
                  [29.10.2021 11:40.35.173] [INFO]  Your configuration file doesn't contain syntax errors :)
                  EDIT:
                  Here is my config file:
                  /* Magic Mirror Config Sample
                   * By Michael Teeuw https://michaelteeuw.nl
                   * MIT Licensed.
                   * see https://docs.magicmirror.builders/getting-started/configuration.html#general
                   * and https://docs.magicmirror.builders/modules/configuration.html
                  let config = {
                  	address: "localhost", 	// Address to listen on, can be:
                  	port: 8080,
                  	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
                  	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
                  	language: "en",
                  	locale: "en-US",
                  	timeFormat: 12,
                  	units: "metric",
                  			module: "alert",
                  			module: "updatenotification",
                  			position: "top_bar"
                  			module: "clock",
                  			clockBold: "true",
                  			position: "top_left"
                  			header: "US Holidays",
                  						symbol: "calendar-check",
                  						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
                  			module: "compliments",
                  			position: "lower_third",
                  				morning: [
                  					"Good Morning, name!"
                  				afternoon: [
                  					"Good Afternoon, name!"
                  				evening: [
                  					"Good Evening, name!"
                  				"....-01-01": [
                  					"Happy New Year, name!"
                  			module: "weather",
                  				type: "current",
                  				locationID: "x", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                  				apiKey: "x",
                  				units: "imperial",
                  				tempUnits: "imperial",
                  				windUnits: "imperial",
                  				timeFormat: "12",
                  				tableClass: "large",
                  				colored: "true"
                   			module: "weather",
                   			header: "Weather Forecast",
                   				type: "forecast",
                   				apiKey: "x"
                  			module: "newsfeed",
                  			position: "bottom_bar",
                  				feeds: [
                  						title: "New York Times",
                  						url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
                  				showSourceTitle: true,
                  				showPublishDate: true,
                  				broadcastNewsFeeds: true,
                  				broadcastNewsUpdates: true
                  S D 2 Replies Last reply Reply Quote 0
                    sdetweil @droidus
                    @droidus in my car but incorrect config for clock and compliments
                    • D
                      droidus @droidus
                      I just found the issue… It is using /home/pi/MagicMirror/modules/default/compliments/compliments.js instead of the config.js file defined compliments…
                      How do I have it use the compliments in the config.js file?
                        sdetweil @droidus
                        @droidus use the correct syntax…
                         module:
                        config:{
                                compliments:
                                          what u have
                        from the documentation
                        	compliments: {
                        		day_sunny: [
                        			"Today is a sunny day",
                        			"It's a beautiful day"
                        		snow: [
                        			"Snowball battle!"
                        		rain: [
                        			"Don't forget your umbrella"
