    MMM-RTSPStream broke after update 2.17.1
    19 Posts 4 Posters 5.3k Views 3 Watching
      sdetweil @JerryP
      @jerryp and the mm start msgs?
      JerryPJ 1 Reply Last reply Reply Quote 0
      • JerryPJ Offline
        JerryP @sdetweil
        sorry
        0|MagicMirror  | Launching application.
        0|MagicMirror  | [18.10.2021 17:14.57.392] [ERROR]
        0|MagicMirror  | Whoops! There was an uncaught exception...
        0|MagicMirror  | [18.10.2021 17:14.57.412] [ERROR]
        0|MagicMirror  | TypeError: Cannot convert undefined or null to object
        0|MagicMirror  |     at Function.keys (<anonymous>)
        0|MagicMirror  |     at stopProcs (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:469:32)
        0|MagicMirror  |     at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:498:17
        0|MagicMirror  |     at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2/lib/API.js:627:19
        0|MagicMirror  |     at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2-axon-rpc/lib/client.js:45:10
        0|MagicMirror  |     at Parser.<anonymous> (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2-axon/lib/sockets/req.js:67:8)
        0|MagicMirror  |     at Parser.emit (events.js:315:20)
        0|MagicMirror  |     at Parser._write (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/amp/lib/stream.js:91:16)
        0|MagicMirror  |     at writeOrBuffer (internal/streams/writable.js:358:12)
        0|MagicMirror  |     at Parser.Writable.write (internal/streams/writable.js:303:10)
        0|MagicMirror  | [18.10.2021 17:14.57.414] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
        0|MagicMirror  | [18.10.2021 17:14.57.416] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
        But the mirror is running. on a PI3B and now I’m out off RAM so lets order a 4B8GB hihihi
          sdetweil @JerryP
          @jerryp so there was an error and the module didn’t handle it.
          swvalentiS 1 Reply Last reply Reply Quote 0
          • swvalentiS Offline
            swvalenti Project Sponsor @sdetweil
            pm2 start omx_stream1
              sdetweil @swvalenti
              @swvalenti then
              pm2 save
              so it will restart on next boot
                @sdetweil my guess is the omx stream was not started by pm2 after the update
                • JerryPJ Offline
                  JerryP @swvalenti
                  @swvalenti
                  No the module was not booting totally. after i make the npm install request. the module is starting only the fault stil is in the log every time I reboot the mirror.
                    sdetweil @JerryP
                    @jerryp this module needs another process to be running IN ADDITION to MM…
                    • JerryPJ Offline
                      JerryP @sdetweil
                      @sdetweil ok. But what’s the solution? off is there no solution for this problem?
                        sdetweil @JerryP
                        @jerryp u were advised to start the other process manually
                        https://forum.magicmirror.builders/topic/15753/mmm-rtspstream-broke-after-update-2-17-1/8?_=1634583021814
