    MMM-RTSPStream broke after update 2.17.1
    19 Posts 4 Posters 5.8k Views 3 Watching
    • JerryPJ Offline
      JerryP @sdetweil
      sorry
      0|MagicMirror  | Launching application.
      0|MagicMirror  | [18.10.2021 17:14.57.392] [ERROR]
      0|MagicMirror  | Whoops! There was an uncaught exception...
      0|MagicMirror  | [18.10.2021 17:14.57.412] [ERROR]
      0|MagicMirror  | TypeError: Cannot convert undefined or null to object
      0|MagicMirror  |     at Function.keys (<anonymous>)
      0|MagicMirror  |     at stopProcs (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:469:32)
      0|MagicMirror  |     at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:498:17
      0|MagicMirror  |     at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2/lib/API.js:627:19
      0|MagicMirror  |     at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2-axon-rpc/lib/client.js:45:10
      0|MagicMirror  |     at Parser.<anonymous> (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2-axon/lib/sockets/req.js:67:8)
      0|MagicMirror  |     at Parser.emit (events.js:315:20)
      0|MagicMirror  |     at Parser._write (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/amp/lib/stream.js:91:16)
      0|MagicMirror  |     at writeOrBuffer (internal/streams/writable.js:358:12)
      0|MagicMirror  |     at Parser.Writable.write (internal/streams/writable.js:303:10)
      0|MagicMirror  | [18.10.2021 17:14.57.414] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      0|MagicMirror  | [18.10.2021 17:14.57.416] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      But the mirror is running. on a PI3B and now I’m out off RAM so lets order a 4B8GB hihihi
        sdetweil @JerryP
        @jerryp so there was an error and the module didn’t handle it.
        swvalentiS 1 Reply Last reply Reply Quote 0
        • swvalentiS Offline
          swvalenti Project Sponsor @sdetweil
          pm2 start omx_stream1
            sdetweil @swvalenti
            @swvalenti then
            pm2 save
            so it will restart on next boot
              @sdetweil my guess is the omx stream was not started by pm2 after the update
              JerryPJ 1 Reply Last reply Reply Quote 0
              • JerryPJ Offline
                JerryP @swvalenti
                @swvalenti
                No the module was not booting totally. after i make the npm install request. the module is starting only the fault stil is in the log every time I reboot the mirror.
                  sdetweil @JerryP
                  @jerryp this module needs another process to be running IN ADDITION to MM…
                  • JerryPJ Offline
                    JerryP @sdetweil
                    @sdetweil ok. But what’s the solution? off is there no solution for this problem?
                      sdetweil @JerryP
                      @jerryp u were advised to start the other process manually
                      https://forum.magicmirror.builders/topic/15753/mmm-rtspstream-broke-after-update-2-17-1/8?_=1634583021814
                      • JerryPJ Offline
                        JerryP @sdetweil
                        @sdetweil Why… the module is running fine after I did what you told me to do. Only the error in the log is there now. but the module is running fine. What will by the use of starting the stream Manuel…
