    MMM-RTSPStream broke after update 2.17.1
    19 Posts 4 Posters 6.9k Views 3 Watching
    • JerryPJ Offline
      JerryP
      pi@raspberrypi:~/MagicMirror/modules/MMM-RTSPStream
      $ npm fund
      mmm-rtspstream@2.0.2-dev
      ├─┬ https://github.com/sponsors/ljharb
      │ └── resolve@1.20.0, is-core-module@2.8.0
      ├─┬ https://github.com/sponsors/RubenVerborgh
      │ └── follow-redirects@1.14.4
      ├─┬ https://github.com/chalk/ansi-styles?sponsor=1
      │ └── ansi-styles@4.3.0
      ├─┬ https://github.com/sponsors/jonschlinkert
      │ └── picomatch@2.3.0
      ├─┬ https://github.com/sponsors/feross
      │ └── safe-buffer@5.2.1, run-series@1.1.9
      ├─┬ https://www.patreon.com/feross
      ├─┬ https://feross.org/support
      ├─┬ https://github.com/sponsors/sindresorhus
      │ └── escape-string-regexp@4.0.0
      ├─┬ https://www.buymeacoffee.com/systeminfo
      │ └── systeminformation@5.9.7
      ├─┬ https://github.com/sponsors/isaacs
      │ └── glob@7.2.0
      └─┬ https://github.com/sponsors/epoberezkin
      └── ajv@6.12.6
        sdetweil @JerryP
        @jerryp and the mm start msgs?
        JerryPJ 1 Reply Last reply Reply Quote 0
        • JerryPJ Offline
          JerryP @sdetweil
          sorry
          0|MagicMirror  | Launching application.
          0|MagicMirror  | [18.10.2021 17:14.57.392] [ERROR]
          0|MagicMirror  | Whoops! There was an uncaught exception...
          0|MagicMirror  | [18.10.2021 17:14.57.412] [ERROR]
          0|MagicMirror  | TypeError: Cannot convert undefined or null to object
          0|MagicMirror  |     at Function.keys (<anonymous>)
          0|MagicMirror  |     at stopProcs (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:469:32)
          0|MagicMirror  |     at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:498:17
          0|MagicMirror  |     at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2/lib/API.js:627:19
          0|MagicMirror  |     at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2-axon-rpc/lib/client.js:45:10
          0|MagicMirror  |     at Parser.<anonymous> (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2-axon/lib/sockets/req.js:67:8)
          0|MagicMirror  |     at Parser.emit (events.js:315:20)
          0|MagicMirror  |     at Parser._write (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/amp/lib/stream.js:91:16)
          0|MagicMirror  |     at writeOrBuffer (internal/streams/writable.js:358:12)
          0|MagicMirror  |     at Parser.Writable.write (internal/streams/writable.js:303:10)
          0|MagicMirror  | [18.10.2021 17:14.57.414] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
          0|MagicMirror  | [18.10.2021 17:14.57.416] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
          But the mirror is running. on a PI3B and now I’m out off RAM so lets order a 4B8GB hihihi
            sdetweil @JerryP
            @jerryp so there was an error and the module didn’t handle it.
            swvalentiS 1 Reply Last reply Reply Quote 0
            • swvalentiS Offline
              swvalenti Project Sponsor @sdetweil
              pm2 start omx_stream1
                sdetweil @swvalenti
                @swvalenti then
                pm2 save
                so it will restart on next boot
                  @sdetweil my guess is the omx stream was not started by pm2 after the update
                  • JerryPJ Offline
                    JerryP @swvalenti
                    @swvalenti
                    No the module was not booting totally. after i make the npm install request. the module is starting only the fault stil is in the log every time I reboot the mirror.
                      sdetweil @JerryP
                      @jerryp this module needs another process to be running IN ADDITION to MM…
                      • JerryPJ Offline
                        JerryP @sdetweil
                        @sdetweil ok. But what’s the solution? off is there no solution for this problem?
                          sdetweil @JerryP
                          @jerryp u were advised to start the other process manually
                          https://forum.magicmirror.builders/topic/15753/mmm-rtspstream-broke-after-update-2-17-1/8?_=1634583021814
                          • JerryPJ Offline
                            JerryP @sdetweil
                            @sdetweil Why… the module is running fine after I did what you told me to do. Only the error in the log is there now. but the module is running fine. What will by the use of starting the stream Manuel…
                              sdetweil @JerryP
                              @jerryp said in MMM-RTSPStream broke after update 2.17.1:
                              ok, you didn’t say it was working
                              what error in the log?
                              did u do pm2 flush to throw away the old messages?
                              • JerryPJ Offline
                                JerryP @sdetweil
                                O Yes it’s running only I’m using for testing a PI3B so this is running out of Ram memory.
                                I also did the flus and still is er a issue when it’s booting pm2 start MagicMirror.
                                0|MagicMirror  | [18.10.2021 21:18.12.312] [ERROR]
                                0|MagicMirror  | [18.10.2021 21:18.12.452] [ERROR]
                                0|MagicMirror  | [18.10.2021 21:18.12.466] [ERROR]
                                0|MagicMirror  | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                0|MagicMirror  | [18.10.2021 21:18.12.473] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                  sdetweil @JerryP
                                  469
                                  the code seems to be trying to connect to the pm2 task for omx stream
                                  looking for the name
                                  which appears to be in this area of the config
                                      stream1: {
                                              name: 'BigBuckBunny Test',   <--- I guess this needs to be the name of the pm2 process..
                                  • BKeyportB Offline
                                    @sdetweil I seem to recall that’s how it worked.
                                    Bottom line is that it’s breaking more and more, and should likely be put in the “yeah, it’s unsupported” pile of past modules.
                                    FWIW, I use my MMM-Block module to slide modules out of the way, and just run the OMX stream directly for now. (Looking for a solution for H.265 streams)
