    MMM-RTSPStream broke after update 2.17.1
    19 Posts 4 Posters 5.7k Views 3 Watching
    • JerryPJ Offline
      JerryP
      After a clean and fresh install mirror crasht whit a black screen.
      pm2 log output
      0|MagicMir |     at require (internal/modules/cjs/helpers.js:88:18)
      0|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:11:15)
      0|MagicMir |     at Module._compile (internal/modules/cjs/loader.js:1078:30)
      0|MagicMir |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1108:10) {
      0|MagicMir |   code: 'MODULE_NOT_FOUND',
      0|MagicMir |   requireStack: [
      0|MagicMir |     '/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js',
      0|MagicMir |     '/home/pi/MagicMirror/js/app.js',
      0|MagicMir |     '/home/pi/MagicMirror/js/electron.js',
      0|MagicMir |     '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
      0|MagicMir |     undefined
      0|MagicMir |   ]
      0|MagicMir | }
      0|MagicMir | [17.10.2021 21:04.27.536] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      Help please.
      This is the config part
      module: "MMM-RTSPStream",
      disabled: false, //false, true
      position: "upper_third",  // "middle_center" "upper_third"
      zoom: -0.6,
      			autoStart: true,
      			rotateStreams: false,
      			rotateStreamTimeout: 20,
      			moduleWidth: 720,
      			moduleHeight: 320,
      			localPlayer: "omxplayer", // "omxplayer" or "ffmpeg", or "vlc"
      			remotePlayer: 'none',
      			showSnapWhenPaused: false,
      			remoteSnaps: false,
      			  stream1: {
      			  name: 'Garage Botter Acker',
      			  url: 'rtsp://User:Pass***@192.168.**.**:554/cam/realmonitor?channel=1&subtype=1',
      			  protocol: "tcp",
      			  frameRate: 25,
      			  muted: true,
      Pm2 -v
      5.1.2
      nam -v
      6.14.15
      node -v
      v14.18.1
        sdetweil @JerryP
        @jerryp a little farther up the log says what module was not found, probably request
        in the module folder, do
        npm install request
        • JerryPJ Offline
          JerryP
          Thanks but this is not working
          This is the log
          pi@raspberrypi:~/MagicMirror/modules/MMM-RTSPStream
          $ npm install request
          + request@2.88.2
          added 43 packages from 50 contributors and audited 244 packages in 26.473s
          11 packages are looking for funding
            run `npm fund` for details
          found 0 vulnerabilities
          • JerryPJ Offline
            JerryP
            $ npm fund
            mmm-rtspstream@2.0.2-dev
            ├─┬ https://github.com/sponsors/ljharb
            │ └── resolve@1.20.0, is-core-module@2.8.0
            ├─┬ https://github.com/sponsors/RubenVerborgh
            │ └── follow-redirects@1.14.4
            ├─┬ https://github.com/chalk/ansi-styles?sponsor=1
            │ └── ansi-styles@4.3.0
            ├─┬ https://github.com/sponsors/jonschlinkert
            │ └── picomatch@2.3.0
            ├─┬ https://github.com/sponsors/feross
            │ └── safe-buffer@5.2.1, run-series@1.1.9
            ├─┬ https://www.patreon.com/feross
            ├─┬ https://feross.org/support
            ├─┬ https://github.com/sponsors/sindresorhus
            │ └── escape-string-regexp@4.0.0
            ├─┬ https://www.buymeacoffee.com/systeminfo
            │ └── systeminformation@5.9.7
            ├─┬ https://github.com/sponsors/isaacs
            │ └── glob@7.2.0
            └─┬ https://github.com/sponsors/epoberezkin
            └── ajv@6.12.6
              sdetweil @JerryP
              @jerryp and the mm start msgs?
              JerryPJ 1 Reply Last reply Reply Quote 0
              • JerryPJ Offline
                JerryP @sdetweil
                sorry
                0|MagicMirror  | Launching application.
                0|MagicMirror  | [18.10.2021 17:14.57.392] [ERROR]
                0|MagicMirror  | Whoops! There was an uncaught exception...
                0|MagicMirror  | [18.10.2021 17:14.57.412] [ERROR]
                0|MagicMirror  | TypeError: Cannot convert undefined or null to object
                0|MagicMirror  |     at Function.keys (<anonymous>)
                0|MagicMirror  |     at stopProcs (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:469:32)
                0|MagicMirror  |     at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:498:17
                0|MagicMirror  |     at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2/lib/API.js:627:19
                0|MagicMirror  |     at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2-axon-rpc/lib/client.js:45:10
                0|MagicMirror  |     at Parser.<anonymous> (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2-axon/lib/sockets/req.js:67:8)
                0|MagicMirror  |     at Parser.emit (events.js:315:20)
                0|MagicMirror  |     at Parser._write (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/amp/lib/stream.js:91:16)
                0|MagicMirror  |     at writeOrBuffer (internal/streams/writable.js:358:12)
                0|MagicMirror  |     at Parser.Writable.write (internal/streams/writable.js:303:10)
                0|MagicMirror  | [18.10.2021 17:14.57.414] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                0|MagicMirror  | [18.10.2021 17:14.57.416] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                But the mirror is running. on a PI3B and now I’m out off RAM so lets order a 4B8GB hihihi
                  sdetweil @JerryP
                  @jerryp so there was an error and the module didn’t handle it.
                  swvalentiS 1 Reply Last reply Reply Quote 0
                  • swvalentiS Offline
                    swvalenti Project Sponsor @sdetweil
                    pm2 start omx_stream1
                      sdetweil @swvalenti
                      @swvalenti then
                      pm2 save
                      so it will restart on next boot
                        @sdetweil my guess is the omx stream was not started by pm2 after the update
