    Any module I add turns to blank screen.
    29 Posts 2 Posters 10.6k Views 2 Watching
      Socrates
      I am new to MM, and i do have some programming knowledge. I understand the concept of braces closing them properly, spacing and closing the loop.
      I have been watching youtube and or going through the read me for each of the modules, i follow the instructions to the dot, i will pick up the api keys, or any kind of custom input needed, but every single module turns my mm to blank screen.
      I have tried VI i have tried nano, i have tried UI mod Scit and text editor, but each time i copy paste any snippet of code from git, I have to end up aligning the code, it never copies to the config file as desired. Hence i wonder if the code snippet copy paste and spacing and tabs is the problem. How do you work with these.
        Socrates
        @sdetweil Dear Sir, you are a genius, i finally got it working. Surely it was an install issue. Using your installation script, and in the past 2 hours i have already inculcated 4 third party modules, and all seems to be working. I might have a question or two later tomorrow when i make more progress, but for now, the main issue is resolved.
          sdetweil @Socrates
          @socrates see https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later/6
          note that blank screen can also be caused by not following the module install instructions
          if the module has a file called package.json, then in the module folder do npm install
          even it the instructions don’t say that , then see the link above
          also see the ‘how to add a module’ link in my signature (I didn’t write it, but its good stuff)
            sdetweil @Socrates
            @socrates also are u doing this with MMOS, or MM installed on a running pi os?
              Socrates @sdetweil
              @sdetweil thanks for your prompt reply. I am running rpi4 OS and then installed MM on it.
              The default out of the box modules (US Holidays calendar, and the
              compliment msgs shows up), but when i add my own google calendar URL that also does not show up.
              Not even a single module i add shows up.
              I am following the instructions as on the modules readme pages. I realize some modules require npm install command even after that i get the same blank screen error.
                Socrates @sdetweil
                Let me give you an example of one of the module I am trying to work with. MMM-DynamicWeather
                See the error logs.
                > magicmirror@2.17.1 start /home/pi/MagicMirror
                [25.10.2021 10:06.30.558] [LOG]   Starting MagicMirror: v2.17.1
                [25.10.2021 10:06.30.570] [LOG]   Loading config ...
                [25.10.2021 10:06.30.577] [LOG]   Loading module helpers ...
                [25.10.2021 10:06.30.579] [LOG]   No helper found for module: alert.
                [25.10.2021 10:06.30.595] [LOG]   Initializing new module helper ...
                [25.10.2021 10:06.30.597] [LOG]   Module helper loaded: updatenotification
                [25.10.2021 10:06.30.598] [LOG]   No helper found for module: clock.
                [25.10.2021 10:06.30.753] [LOG]   Initializing new module helper ...
                [25.10.2021 10:06.30.754] [LOG]   Module helper loaded: calendar
                [25.10.2021 10:06.30.755] [LOG]   No helper found for module: compliments.
                [25.10.2021 10:06.30.758] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'request'
                Require stack:
                - /home/pi/MagicMirror/modules/MMM-DynamicWeather/node_helper.js
                /* Magic Mirror Config Sample
                 * By Michael Teeuw https://michaelteeuw.nl
                 * MIT Licensed.
                 * see https://docs.magicmirror.builders/getting-started/configuration.html#general
                 * and https://docs.magicmirror.builders/modules/configuration.html
                let config = {
                	address: "localhost", 	// Address to listen on, can be:
                	port: 8555,
                	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
                	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
                	language: "en",
                	locale: "en-US",
                	timeFormat: 24,
                //	units: "metric",
                			module: "alert",
                			module: "updatenotification",
                			position: "top_bar"
                			module: "clock",
                			position: "top_left"
                			header: "iUS Holidays",
                						symbol: "calendar-check",
                						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics",
                						symbol: "Koshy-Family-Calendar",
                						url: "https://calendar.google.com/calendar/ical/luvology%40gmail.com/public/basic.ics"
                			module: "compliments",
                			position: "lower_third"
                //			module: "weather",
                //			position: "top_right",
                //			config: {
                //				weatherProvider: "openweathermap",
                //				type: "current",
                //				location: "Houston",
                //				units: "imperial",
                //				locationID: "2646507", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                //				apiKey: "98dbcccba012ef0fd49c86665a0df584"
                //			module: "weatherforecast",
                //			header: "Weather Forecast",
                //			config: {
                //				locationID: '2646507',
                //				app_id: '98dbcccba012ef0fd49c86665a0df584',
                //				units: 'imperial'
                		module: "MMM-DynamicWeather",
                		position: "fullscreen_above",
                		config: { // See https://github.com/scottcl88/MMM-DynamicWeather for more information.
                 			api_key: "98dbcccba012ef0fd49c86665a0df584",
                 			effects: [
                    					month: "10",
                    					day: "25",
                    					year: "2021",
                    					images: ["heart1.png", "heart2.png"],
                    					direction: "up"
                			module: "newsfeed",
                			position: "bottom_bar",
                				feeds: [
                						title: "CNN News",
                						url: "http://rss.cnn.com/rss/cnn_world.rss"
                				showSourceTitle: true,
                				showPublishDate: true,
                				broadcastNewsFeeds: true,
                				broadcastNewsUpdates: true
                  Socrates
                  More troubleshooting logs as per the link provided in this post.
                  pi@raspberrypi:~/MagicMirror/modules/MMM-Dynamic-Modules $ npm install request
                  npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                  npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                  npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                  + request@2.88.2
                  updated 1 package and audited 48 packages in 2.163s
                  found 0 vulnerabilities
                  pi@raspberrypi:~/MagicMirror/modules/MMM-Dynamic-Modules $ npm install uuid
                  + uuid@8.3.2
                  added 1 package from 5 contributors, updated 1 package and audited 49 packages in 1.85s
                  2 packages are looking for funding
                    run `npm fund` for details
                  pi@raspberrypi:~/MagicMirror/modules/MMM-Dynamic-Modules $ npm fund
                  MMM-Dynamic-Modules@1.0.0
                  ├─┬ https://github.com/sponsors/feross
                  │ └── safe-buffer@5.2.1
                  ├─┬ https://www.patreon.com/feross
                  ├─┬ https://feross.org/support
                  └─┬ https://github.com/sponsors/epoberezkin
                    └── ajv@6.12.6
                    sdetweil @Socrates
                    @socrates said in Any module I add turns to blank screen.:
                    Cannot find module ‘request’
                    see the link I gave you in my 1st reply
                    but looks like u are moving in the right direction
                      Socrates @sdetweil
                      @sdetweil thanks see my third post , i have the logs uploaded when i tried to install request using
                      npm install request
                      and then it shows three more packages that are depreciated.
                      Not able to install none of those.
                      S S 2 Replies Last reply Reply Quote 0
                        sdetweil @Socrates
                        don’t worry about that… one step at a time…
                        don’t do npm fund unless u want to contribute money to other developers (outside MM)
                          Socrates @Socrates
                          Do u think i should install MM some other way? I cannot think of anything else.
                            sdetweil @Socrates
                            @socrates well, i would start with one module at a time…
                            save the current config.js
                            copy the config.js.sample to config.js
                            confirm MM runs
                            add one module
                            resolve any missing dependencies
                            i don’t THINK u need to resinstall, but if u want to
                            then use my install script… see
                            it doesn’t look like config.js editing is the problem, but if so, try my MMM-Config module which generates a form for config , see
                            https://github.com/sdetweil/MMM-Config
                            but missing libs are a pain in the rear… just no way to know when it will hit
                            note that the instructions link I posted will load ‘request’ or any other missing lib
                            IN THE MODULE folder
                            so, if u find ANOTHER module with the same problem, then u have to load it THERE TOO
                            over and over
                            you can do it in the MM folder instead, BUT… be warned… if you do an upgrade, the libs will be tossed as they are not referenced by the base, and are considered a security risk (in NPM, not the MM code) so, you could get to do it all over again, …
                            (I am considering making a change to my upgrade script to try and detect this… not sure yet)
                              Socrates @sdetweil
                              @sdetweil Thanks i am gonna follow these steps and let you know.
                              I am literally installing one module at a time, but none of the 3rd party module works. Even if i try to edit the inbuilt module that MM came with for eg:- the calendar, i try to add my own google calendar, it wont work. (meaning my calendar wont show up).
                              Do u have recommendations of which modules i can initially start with so that all the basic pre-requisite libraries get installed?
                                sdetweil @Socrates
                                @socrates the defaults ones work pretty reliably…
                                for mail, the url for the cal ics lnk should download the ics file when used in a browser…
                                that is what the cal modules uses
                                what modules have u been trying over than default?
                                  Socrates @sdetweil
                                  I have tried todoist, the calander ext2 module, dynamic weather module, several others. I think i might have an installation issue… I will just reformat my card and re-install using your script.
                                  So after i install rpi, do i run ur script in terminal, and follow the prompts?
                                    sdetweil @Socrates
                                    yes, just copy paste the one line for install in a terminal window
                                      Socrates @sdetweil
                                      So i have installed mm using your script, and i am up and running, havent installed the modules yet, but that is because i am not able to shutdown mm using pm2 command, mm has been started using pm2 via your script.
                                      None of these commands work
                                      pm2 restart mm
                                      pm2 stop mm
                                        sdetweil @Socrates
                                        pm2 stop mm
                                        cause its not called mm…
                                        pm2 status
                                        will show u the name , you can also use the number
                                        or all to stop everything
                                          Socrates
                                            Socrates
                                            So everything is working out great for me, i have added some great modules, and in the processing of adding more.
                                            The only one thing i am not able to figure out is the measure of unit for the weather.
                                            I am in the US, in texas, and even if i use the imperial unit it wont show it correctly and the weather is totally off.
        module: "MMM-Weather",
        header: "Weather Forecast - Katy, TX",
        configDeepMerge: true,
        debug: false,
        updateInterval: "15m", // 15 minutes
        updateFadeSpeed: 500,
        api: {
        latitude: "29.71490",
        longitude: "95.83688",
        units: "imperial"
        display: {
        CurrentConditions: true,
        ExtraCurrentConditions: true,
        Summary: true,
        ForecastTableColumnHeaderIcons: true,
        HourlyForecast: true,
        DailyForecast: true,
        Precipitation: true,
        Wind: true,
        InlineIcons: true,
        Feels: true,
        SunCondition: true,
        Humidity: true,
        UV: true,
        Beaufort: true
        personalize: {
        hourlyForecastInterval: 3,
        maxHourliesToShow: 3,
        maxDailiesToShow: 3,
        concise: false,
        colored : true,
        forecastLayout: "table",
        forecastHeaderText: ""
        labels: {
        high: "H",
        low: "L",
        timeFormat: "kk[h]"
                                            Have a look a this code.. and the partial screenshot of my magic mirror through vnc viewer
                                              Socrates
                                              alt text
