    Any module I add turns to blank screen.
    29 Posts 2 Posters 10.7k Views 2 Watching
      sdetweil @Socrates
      @socrates said in Any module I add turns to blank screen.:
                           longitude: "95.83688",
      we are west of england, so longitude should be negative (right?)… I am in texas too,
      so, if u fix that and leave units off, it will take from the top of config
        Socrates @sdetweil
        Gosh, my parcel got delivered in Europe… :beaming_face_with_smiling_eyes:
        The dashboard is starting to take shape.
        alt text
        A few more important modules and i am set.
          sdetweil @Socrates
          more like central China!
            Socrates @sdetweil
            hahaha
              sdetweil @Socrates
              @socrates easy, maps.google.com, get the map of your location, in the url, delete the minus sign on longitude, and press enter
              it will map that location… zoom out til u figure out where that is
                Socrates
                Thank you for your help. I have successfully managed to add quite a bit of useful modules as per my requirements, and have added styling to the fonts etc.
                However there are two things I am unable to get around.
                First is the wallpaper module.
                If i use the default bing option for the source, it wont show more than 10 wallpapers, i have tried to change the “maximumEntries” to 20 or more and it still wont show more than the original 10 wallpapers it loaded the first day (3 days back). Then i tried to change the source to Flickr groups, and it wont show anything now. Please have a look at my code snippet below.
                                        module: "MMM-Wallpaper",
                                        position: "fullscreen_below",
                                        config: { // See "Configuration options" for more information.
                                        source: "flickr-group:113291043@N05",
                                        maximumEntries: "20",
                                        slideInterval: 60 * 1000 // Change slides every minute
                The second item is, i am not able to increase the calendar items, right now it only shows me 5 or 6 items, i am trying to increase it to 10 and it still show the default items.
                see below.
                                        header: "Holidays & Reminders",
        symbol: "calendar-check",
        url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics",
        maximumEntries: 20,
        url: "https://calendar.google.com/calendar/ical/lxxxxxxxxx.ics",
        maximumEntries: 20
                  sdetweil @Socrates
                  @socrates
                  maximumEntries
                  goes outside the calendars list
                                                 maximumEntries: 10,
                  is ALL calendars,. outside the calendars list
                  Calendar configuration options:
                  is per calendar
                    Socrates @sdetweil
                    GOsh thanks that worked.
                    Any idea about the wallpaper part? I would like to inculcate flickr group, but the code snippet wont work.
                      sdetweil @Socrates
                      maximumEntries: “20”,
                      maybe,
                      numbers should never be in quotes
