    Calendar events showing on wrong day.
    66 Posts 3 Posters 35.8k Views 3 Watching
    • Coolie1101C Offline
      Coolie1101 @sdetweil
      @sdetweil said in Calendar events showing on wrong day.:
      (I am central US time)
      Don’t sleep much :grinning_face:
        sdetweil @Coolie1101
        @coolie1101 said in Calendar events showing on wrong day.:
        Don’t sleep much
        its past 8am… been up since 6 (cat wakes me reliably)
          @coolie1101 you cant run with pm2 AND with npm start
          so, thats why I said
          pm2 stop all
          THEN (in the MagicMirror folder)
          npm start
          Got it, I edited the “calendarutils.js” file again and restarted, no error or calendar entries in log, but the display is the same.
            @coolie1101 weird
            edit config.js and change
            	logLevel: ["INFO", "LOG", "WARN", "ERROR"]
            to
            this
            	logLevel: ["INFO", "LOG", "WARN","ERROR","DEBUG"]
            and run again, then u will see the calendar processing
            Coolie1101C 1 Reply Last reply Reply Quote 0
              @coolie1101 and a reminder, there are TWO sections of code u have to comment out
              two areas of two lines each
                @sdetweil Yes.
                Line 348 & 358
                //								if (event.start.tz === moment.tz.guess()) {
                									// if the date hour is less than the offset
                									if (24 - dh < Math.abs(dateoffset / 60)) {
                										// apply the correction to the date/time back to right day
                										date = new Date(date.getTime() + Math.abs(24 * 60) * 60000);
                										// the duration was calculated way back at the top before we could correct the start time..
                										// fix it for this event entry
                										//duration = 24 * 60 * 60 * 1000;
                										Log.debug("new recurring date2 is " + date);
                Line 376 & 386
                  Will it work like this “npm start >cal_test_log.txt | grep calendar”?
                    no…
                    something like this (couple debug lines added for my testing)
                    [19.11.2021 07:50.24.603] [DEBUG] Processing entry...
                    Event: {"type":"VEVENT","params":[],"start":"2021-04-06T09:00:00.000Z","datetype":"date-time","end":"2021-04-06T14:00:00.000Z","rrule":{"_cache":{"all":false,"before":[],"after":[],"between":[]},"origOptions":{"dtstart":"2021-04-06T09:00:00.000Z","freq":2,"wkst":{"weekday":6},"until":"2021-12-30T04:59:59.000Z","byweekday":[{"weekday":1}]},"options":{"freq":2,"dtstart":"2021-04-06T09:00:00.000Z","interval":1,"wkst":6,"count":null,"until":"2021-12-30T04:59:59.000Z","bysetpos":null,"bymonth":null,"bymonthday":[],"bynmonthday":[],"byyearday":null,"byweekno":null,"byweekday":[1],"bynweekday":null,"byhour":[9],"byminute":[0],"bysecond":[0],"byeaster":null}},"dtstamp":"2021-11-19T12:42:16.000Z","uid":"0v89h5cit8nq6mfribble@google.com","created":"2021-10-26T07:58:43.000Z","description":"","lastmodified":"2021-10-26T08:02:54.000Z","location":"","sequence":"1","status":"CONFIRMED","summary":"YARD WASTE","transparency":"OPAQUE"}
                    [19.11.2021 07:50.24.603] [DEBUG] startDate (local): Tue Apr 06 2021 04:00:00 GMT-0500 (Central Daylight Time)
                    [19.11.2021 07:50.24.603] [DEBUG] endDate (local): Tue Apr 06 2021 09:00:00 GMT-0500 (Central Daylight Time)
                    [19.11.2021 07:50.24.604] [DEBUG] duration: 18000000
                    [19.11.2021 07:50.24.604] [DEBUG] title: YARD WASTE
                    [19.11.2021 07:50.24.604] [DEBUG] Search for recurring events between: Fri Nov 19 2021 07:50:24 GMT-0600 (Central Standard Time) and Fri Nov 18 2022 23:59:59 GMT-0600 (Central Standard Time)
                    [19.11.2021 07:50.24.605] [DEBUG] Title: YARD WASTE, with dates: ["2021-11-23T09:00:00.000Z","2021-11-30T09:00:00.000Z","2021-12-07T09:00:00.000Z","2021-12-14T09:00:00.000Z","2021-12-21T09:00:00.000Z","2021-12-28T09:00:00.000Z"]
                    [19.11.2021 07:50.24.605] [DEBUG] event.recurrences: undefined
                    [19.11.2021 07:50.24.605] [DEBUG]  recurring date is Tue Nov 23 2021 03:00:00 GMT-0600 (Central Standard Time) offset is 360
                    [19.11.2021 07:50.24.605] [DEBUG]  recurring date is Tue Nov 23 2021 03:00:00 GMT-0600 (Central Standard Time) offset is 6 Hour is 03
                    [19.11.2021 07:50.24.606] [DEBUG] not full day
                    [19.11.2021 07:50.24.606] [DEBUG] offset positive
                    [19.11.2021 07:50.24.606] [DEBUG] Corrected startDate (local): Tue Nov 23 2021 03:00:00 GMT-0600 (Central Standard Time)
                    [19.11.2021 07:50.24.606] [DEBUG] initial tz=America/New_York
                    [19.11.2021 07:50.24.606] [DEBUG] corrected tz=America/New_York
                    [19.11.2021 07:50.24.606] [DEBUG] start date/time=Tue Apr 06 2021 04:00:00 GMT-0500 (Central Daylight Time)
                    [19.11.2021 07:50.24.606] [DEBUG] start offset=-240
                    [19.11.2021 07:50.24.606] [DEBUG] start date/time w tz =Tue Apr 06 2021 04:00:00 GMT-0500 (Central Daylight Time)
                    [19.11.2021 07:50.24.606] [DEBUG] event date=Tue Nov 23 2021 03:00:00 GMT-0600 (Central Standard Time)
                    [19.11.2021 07:50.24.606] [DEBUG] event offset=-300 hour=4 event date=Tue Nov 23 2021 03:00:00 GMT-0600 (Central Standard Time)
                    [19.11.2021 07:50.24.606] [DEBUG] adjust up 1 hour dst change
                    [19.11.2021 07:50.24.606] [DEBUG] adjustHours=1
                    [19.11.2021 07:50.24.606] [DEBUG] duration: 18000000
                    [19.11.2021 07:50.24.607] [DEBUG] saving event: false
                      @sdetweil It’s running, how long should I wait before checking the output file?, as there is no output in the ssh window.
                        @coolie1101 til the calendar comes up with the wrong displayed info
                        then ctrl-c to end
                          @sdetweil Here’s the out in the file.
                          > magicmirror@2.17.1 start /home/pi/MagicMirror
                          [19.11.2021 09:42.53.017] [LOG]   Starting MagicMirror: v2.17.1
                          [19.11.2021 09:42.53.028] [LOG]   Loading config ...
                          [19.11.2021 09:42.53.041] [LOG]   Loading module helpers ...
                          [19.11.2021 09:42.53.456] [LOG]   Initializing new module helper ...
                          [19.11.2021 09:42.53.458] [LOG]   Module helper loaded: MMM-Remote-Control
                          [19.11.2021 09:42.53.461] [LOG]   No helper found for module: alert.
                          [19.11.2021 09:42.53.469] [LOG]   Initializing new module helper ...
                          [19.11.2021 09:42.53.471] [LOG]   Module helper loaded: updatenotification
                          [19.11.2021 09:42.53.472] [LOG]   No helper found for module: clock.
                          [19.11.2021 09:42.53.782] [LOG]   Initializing new module helper ...
                          [19.11.2021 09:42.53.784] [LOG]   Module helper loaded: calendar
                          [19.11.2021 09:42.55.195] [LOG]   Initializing new module helper ...
                          [19.11.2021 09:42.55.196] [LOG]   Module helper loaded: MMM-TelegramBot
                          [19.11.2021 09:42.55.203] [LOG]   Initializing new module helper ...
                          [19.11.2021 09:42.55.204] [LOG]   Module helper loaded: MMM-Detector
                          [19.11.2021 09:42.55.987] [LOG]   Initializing new module helper ...
                          [19.11.2021 09:42.55.997] [LOG]   Module helper loaded: MMM-GoogleAssistant
                          [19.11.2021 09:42.55.999] [LOG]   No helper found for module: MMM-JokeAPI.
                          [19.11.2021 09:42.56.001] [LOG]   No helper found for module: weather.
                          [19.11.2021 09:42.56.181] [LOG]   Initializing new module helper ...
                          [19.11.2021 09:42.56.183] [LOG]   Module helper loaded: MMM-Tools
                          [19.11.2021 09:42.56.900] [LOG]   Initializing new module helper ...
                          [19.11.2021 09:42.56.902] [LOG]   Module helper loaded: MMM-MotionDisplay
                          [19.11.2021 09:42.56.955] [LOG]   Initializing new module helper ...
                          [19.11.2021 09:42.56.957] [LOG]   Module helper loaded: newsfeed
                          [19.11.2021 09:42.56.958] [LOG]   All module helpers loaded.
                          [19.11.2021 09:42.57.123] [LOG]   Starting server on port 8080 ...
                          [19.11.2021 09:42.57.139] [LOG]   Server started ...
                          [19.11.2021 09:42.57.142] [LOG]   Connecting socket for: MMM-Remote-Control
                          [19.11.2021 09:42.57.144] [LOG]   Starting node helper for: MMM-Remote-Control
                          [19.11.2021 09:42.57.157] [LOG]   Connecting socket for: updatenotification
                          [19.11.2021 09:42.57.159] [LOG]   Connecting socket for: calendar
                          [19.11.2021 09:42.57.161] [LOG]   Starting node helper for: calendar
                          [19.11.2021 09:42.57.163] [LOG]   Connecting socket for: MMM-TelegramBot
                            @coolie1101 there should be lots more
                            I only need to see the processing of that one cal entry
                            Coolie1101C 2 Replies Last reply Reply Quote 0
                              @sdetweil That’s everything in the file, I did tail the file, but the out is alot.
                                @coolie1101 can’t be everything
                                cause there are default messages for calendar not shown
                                u did add the “DEBUG”, right
                                  Event: {"type":"VEVENT","params":[],"start":"2021-04-06T09:00:00.000Z","datetype":"date-time","end":"2021-04-06T14:00:00.000Z","dtstamp":"2021-11-19T14:43:09.000Z","uid":"0v89h5cit8nq6m************@google.com","created":"2021-10-26T07:58:43.000Z","description":"","lastmodified":"2021-10-26T08:02:54.000Z","location":"","sequence":"1","status":"CONFIRMED","summary":"YARD WASTE","transparency":"OPAQUE","recurrences":{"2021-11-02":{"type":"VEVENT","params":[],"start":"2021-11-03T09:00:00.000Z","datetype":"date-time","end":"2021-11-03T14:00:00.000Z","dtstamp":"2021-11-19T14:43:09.000Z","uid":"0v89h5cit8nq6m************@google.com","recurrenceid":"2021-11-02T09:00:00.000Z","created":"2021-10-26T07:58:43.000Z","description":"","lastmodified":"2021-10-26T08:02:54.000Z","location":"","sequence":"2","status":"CONFIRMED","summary":"YARD WASTE","transparency":"OPAQUE"},"2021-10-12":{"type":"VEVENT","params":[],"start":"2021-10-13T09:00:00.000Z","datetype":"date-time","end":"2021-10-13T14:00:00.000Z","dtstamp":"2021-11-19T14:43:09.000Z","uid":"0v89h5cit8nq6m************@google.com","recurrenceid":"2021-10-12T09:00:00.000Z","created":"2021-10-26T07:58:43.000Z","description":"","lastmodified":"2021-10-26T08:02:54.000Z","location":"","sequence":"2","status":"CONFIRMED","summary":"YARD WASTE","transparency":"OPAQUE"},"2021-09-07":{"type":"VEVENT","params":[],"start":"2021-09-08T09:00:00.000Z","datetype":"date-time","end":"2021-09-08T14:00:00.000Z","dtstamp":"2021-11-19T14:43:09.000Z","uid":"0v89h5cit8nq6m************@google.com","recurrenceid":"2021-09-07T09:00:00.000Z","created":"2021-10-26T07:58:43.000Z","description":"","lastmodified":"2021-10-26T08:02:54.000Z","location":"","sequence":"2","status":"CONFIRMED","summary":"YARD WASTE","transparency":"OPAQUE"},"2021-07-06":{"type":"VEVENT","params":[],"start":"2021-07-07T09:00:00.000Z","datetype":"date-time","end":"2021-07-07T14:00:00.000Z","dtstamp":"2021-11-19T14:43:09.000Z","uid":"0v89h5cit8nq6m************@google.com","recurrenceid":"2021-07-06T09:00:00.000Z","created":"2021-10-26T07:58:43.000Z","description":"","lastmodified":"2021-10-26T08:02:54.000Z","location":"","sequence":"2","status":"CONFIRMED","summary":"YARD WASTE","transparency":"OPAQUE"},"2021-06-01":{"type":"VEVENT","params":[],"start":"2021-06-02T09:00:00.000Z","datetype":"date-time","end":"2021-06-02T14:00:00.000Z","dtstamp":"2021-11-19T14:43:09.000Z","uid":"0v89h5cit8nq6m************@google.com","recurrenceid":"2021-06-01T09:00:00.000Z","created":"2021-10-26T07:58:43.000Z","description":"","lastmodified":"2021-10-26T08:02:54.000Z","location":"","sequence":"2","status":"CONFIRMED","summary":"YARD WASTE","transparency":"OPAQUE"}},"rrule":{"_cache":{"all":false,"before":[],"after":[],"between":[]},"origOptions":{"dtstart":"2021-04-06T09:00:00.000Z","freq":2,"wkst":{"weekday":6},"until":"2021-12-30T04:59:59.000Z","byweekday":[{"weekday":1}]},"options":{"freq":2,"dtstart":"2021-04-06T09:00:00.000Z","interval":1,"wkst":6,"count":null,"until":"2021-12-30T04:59:59.000Z","bysetpos":null,"bymonth":null,"bymonthday":[],"bynmonthday":[],"byyearday":null,"byweekno":null,"byweekday":[1],"bynweekday":null,"byhour":[9],"byminute":[0],"bysecond":[0],"byeaster":null}}}
                                    @coolie1101 unless u didn’t stop pm2 running instance
                                      I did, “pm2 stop all”, then “npm start file_name.txt”
                                      Yes.
                                      language: “en”,
                                      locale: “en-US”,
                                      logLevel: [“INFO”, “LOG”, “WARN”,“ERROR”,“DEBUG”], // Add “DEBUG” for even more logging
                                      timeFormat: 24,
                                      units: “imperial”,
                                        and with the > symbol
                                        npm start > file_name.txt
                                          @sdetweil So I deleted the entry for that day and added back just for that day, it shows up correct in the display but the following events still shows a day late.
                                            so, I need to see THAT vevent
                                            • 2 / 4
