    Module programming preview, jsfiddle?
    11 Posts 5 Posters 8.9k Views 5 Watching
    • morozgrafixM Offline
      morozgrafix Moderator @washichi
      @washichi Interesting idea for the module. And glancing at your code you seem to be on the right track.
      I may be not understanding what you trying Sublime Text to do. It’s just a text editor with ability to add various packages on top of it. It’s not a full blown IDE. I don’t believe that you can compile or preview the JavaScript module directly in Sublime.
      My general workflow for module creation is something like this:
      1. Create MMM-mymodule directory inside MagicMirror/modules
      2. Open MagicMirror directory in sublime
      3. Add barebones config for the module to modules array in config.js, for example:
      	module: "MMM-mymodule",
      	position: "bottom_right",
      	config : {
      1. Start node serveronly and point my Chrome with dev tools open to the http://localhost:8080
      2. Create/edit MagicMirror/modules/MMM-mymodule/MMM-mymodule.js, save it. (or other files that you need for the module)
      3. Refresh the browser to pickup my changes, debug etc.
      4. Repeat steps 5-6 as I go along. If adding/editing node_helper.js repeat steps 4-6 since node needs to pickup that file.
      Some of restarts/refreshes can be automated on file save with different tools, but I’m not going to get into that right now.
