    Module load control via Face-Reco
    4 Posts 2 Posters 949 Views 2 Watching
    • M
      mm1964
      Re: MMM-Face-Reco-DNN - All new Face Recognition
      I have installed this module and it works well when hiding modules based on the face recognised. Is there a way to use this module to control which modules actually load in MM.
      I wanted to play a short welcome mp3 message based on user logged in.
      I have tried using the MP3 player module, but it loads both profiles as it only hised them from the dispaly, I want to disable certain modules based on user.
        sdetweil @mm1964
        @mm1964 no. mm loads all modules listed in config.js, only at startup time.
        M 1 Reply Last reply
        • M
          mm1964 @sdetweil
          Once again thank you, from what you are saying we can only hide active modules based on the user and classes.
          I have had another thought, what if I install Face Regcog outside MM and have 2 config files and based on the user it ID’s loads one one 2 config files.
          The would obviously be a delay in start, but could this work?
            sdetweil @mm1964
            @mm1964 no idea on that.
