    Problem whit MMM-PIE-Sensor modules
    5 Posts 4 Posters 900 Views 4 Watching
      mecco86
      Hello, and happy new year, After a new update of magic mirror, pir modules don’t work.
      pi@raspberrypi:~ $ cd MagicMirror
      magicmirror@2.18.0 start /home/pi/MagicMirror
      DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
      [01.01.2022 23:44.15.704] [LOG] Starting MagicMirror: v2.18.0
      [01.01.2022 23:44.15.712] [LOG] Loading config …
      [01.01.2022 23:44.15.720] [LOG] Loading module helpers …
      [01.01.2022 23:44.15.765] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module ‘/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build/Release/epoll.node’
      was compiled against a different Node.js version using
      NODE_MODULE_VERSION 83. This version of Node.js requires
      NODE_MODULE_VERSION 99. Please try re-compiling or re-installing
      the module (for instance, using npm rebuild or npm install).
      [01.01.2022 23:44.15.767] [LOG] Loading module helpers …
      [01.01.2022 23:44.15.774] [ERROR] App threw an error during load
      [01.01.2022 23:44.15.776] [ERROR] Error: The module ‘/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build/Release/epoll.node’
      at process.func [as dlopen] (node:electron/js2c/asar_bundle:5:1800)
      at Object.Module._extensions…node (node:internal/modules/cjs/loader:1199:18)
      at Object.func [as .node] (node:electron/js2c/asar_bundle:5:1800)
      at Module.load (node:internal/modules/cjs/loader:988:32)
      at Module._load (node:internal/modules/cjs/loader:829:12)
      at Function.c._load (node:electron/js2c/asar_bundle:5:13331)
      at Module.require (node:internal/modules/cjs/loader:1012:19)
      at require (node:internal/modules/cjs/helpers:94:18)
      at bindings (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bindings/bindings.js:112:48)
      at /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/epoll.js:7:31
      [01.01.2022 23:44.15.778] [ERROR] Whoops! There was an uncaught exception…
      [01.01.2022 23:44.15.784] [ERROR] Error: The module ‘/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build/Release/epoll.node’
      at /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/epoll.js:7:31 {
      code: ‘ERR_DLOPEN_FAILED’
      [01.01.2022 23:44.15.787] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      [01.01.2022 23:44.15.788] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      [01.01.2022 23:44.16.160] [LOG] Launching application.
      [01.01.2022 23:44.23.203] [LOG] Shutting down server…
      [01.01.2022 23:44.23.209] [ERROR] Whoops! There was an uncaught exception…
      [01.01.2022 23:44.23.216] [ERROR] TypeError: Cannot read properties of undefined (reading ‘close’)
      at App.stop (/home/pi/MagicMirror/js/app.js:257:14)
      at App. (/home/pi/MagicMirror/js/electron.js:139:7)
      at App.emit (node:events:394:28)
      at appMethod (node:electron/js2c/browser_init:69:1830
        sdetweil @mecco86
        @mecco86 in the MMM-PIR-Sensor folder do
        npm rebuild
        https://docs.npmjs.com/cli/v7/commands/npm-rebuild
        actually, don’t do that
        that is needed for server only mode
        do
        cd ~/MagicMirror
        npm install electron-rebuild --save
        cd modules/MMM-PIR-Sensor
        ../../node_modules/bin/electron-rebuild
          JoeFranz @sdetweil
          @sdetweil don’t work here :-(
          /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
          0|MagicMir | at bindings (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bindings/bindings.js:112:48)
          0|MagicMir | at /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/epoll.js:7:31 {
          0|MagicMir | code: ‘ERR_DLOPEN_FAILED’
          0|MagicMir | }
          0|MagicMir | [02.01.2022 17:15.53.329] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
          0|MagicMir | [02.01.2022 17:15.53.332] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
          0|MagicMir | [4288:0102/171555.340330:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
          0|MagicMir | [4321:0102/171555.638445:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
          0|MagicMir | [02.01.2022 17:18.59.907] [ERROR] Whoops! There was an uncaught exception…
          0|MagicMir | [02.01.2022 17:18.59.912] [ERROR] TypeError: Cannot read properties of undefined (reading ‘close’)
          0|MagicMir | at App.stop (/home/pi/MagicMirror/js/app.js:257:14)
          0|MagicMir | at App. (/home/pi/MagicMirror/js/electron.js:139:7)
          0|MagicMir | at App.emit (node:events:394:28)
          0|MagicMir | [02.01.2022 17:18.59.913] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
          0|MagicMir | [02.01.2022 17:18.59.914] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
          bugsounetB 1 Reply Last reply Reply Quote 0
          • bugsounetB Offline
            bugsounet Banned @JoeFranz
            @joefranz : I think, this can help
            Warn: MM v2.18.x needs nodejs v14.x or v16.x :)
            to verify, just try this commands:
            node -v
              JoeFranz @bugsounet
              @bugsounet said in Problem whit MMM-PIE-Sensor modules:
              node -v
              pi@raspberrypi:~/MagicMirror $ node -v
              v16.13.1
              It works now, thank you :-)
