    MMM-Hue CORS Policy Issue
    28 Posts 7 Posters 13.6k Views 7 Watching
    • karsten13K
      karsten13 @OberfragGER
      @oberfragger
      can you access the mirror with https://<ip-of-pi>:8080?
      May you are using a client which is not in the ipWhitelist? You can test this with setting ipWhitelist: [], in your config.js.
      • O
        OberfragGER @karsten13
        @karsten13 said in MMM-Hue CORS Policy Issue:
        https://:8080
        No. Thats excactly what im telling you:
        When
          address: "localhost",
        then i dont have any access to https://ip-of-pi:8080 or http://ip-of-pi:8080.
        When
        address: '0.0.0.0',
        i have no problem to access Remote-Control-Gui/ Webpage. The ipWhitelist is aready set.
          sdetweil @OberfragGER
          @oberfragger correct… localhost means ONLY apps INSIDE the same machine can connect.
          so you could open a browser ON THE PI screen and connect, but not from another device
          0.0.0.0 means listen for incoming connections on all network interfaces
          (Ethernet and wifi at once, on pi4 if both enabled)
          • O
            OberfragGER @sdetweil
            @sdetweil Thank you for you clarification.
            Thats really not good. So i have to decide to get rid og MMM-Motioneye for another camera module which is working…or not to use MMM-Remotecontrol… or not to Update from 2.17 (i have an old image with a fresh install).
              @oberfragger you might try with address:“192.168.x.y”
              where x and y are from the IP address of the mm machine
              • O
                @sdetweil said in MMM-Hue CORS Policy Issue:
                Hey @sdetweil,
                sorry for the late reply. Thanks for your help, again. With that, i have MM running with 2.18 an d MMM-Motionseye is displaying the stream.
                Thanks a lot.
                Edit: For anyone who reads this. After set
                adress: "192.168.X.X"
                the module GoogleBirthdaysProvider was not working any longer due the config of that module.
                Just change
                url: 'http://localhost:8080/mmm-googlebirthdaysprovider',
                to
                url: 'http://192.168.X.X:8080/mmm-googlebirthdaysprovider',
                  @oberfragger just to let you know ip
                  addresses
                  192.168
                  and
                  10.
                  are not routable over the internet . they are intended only for local private networks. so having your full address doesn’t allow anyone to access it unless they are also on your network. (if they are on your network, they can find all the active addresses in a few seconds.
                  my desktop is 192.168.2.106
                  • spitzlbergerjS
                    spitzlbergerj Project Sponsor Module Developer @CarstenD
                    @CarstenD said in MMM-Hue CORS Policy Issue:
                    There is now a new version available for MMM-Homematic that also works w/o changing the config.
                    Hi @CarstenD ,
                    where can I find this new version? At https://github.com/Sickboy78/MMM-Homematic is still the old version.
                    Sorry, but i don’t get it
                    Regards
                    Josef
                    Regards
                    Josef
                    http://www.spitzlberger.de/smartmirror, https://github.com/spitzlbergerj/MMM-TeslaLogger, https://github.com/spitzlbergerj/CaravanPi, https://www.la-gondola-barocca.de
                    • M MisterT referenced this topic on
