    MMM-MyWastePickup date problem
    18 Posts 7 Posters 4.6k Views 7 Watching
      JohndB @MyMirror
      @mymirror
      Hi there,
      I recently installed this module and found no problems.
      Hereby a screenshot from the last lines in the csv file.f482bdba-87ed-40fb-9e4a-58c38f2e0755-image.png
      and a screenshot to show you that it works;
      Best regards,
      John
        MyMirror @JohndB
        @johndb
        ?? Without “Custom” in the beginning of every line?
        As described here https://github.com/jclarke0000/MMM-MyWastePickup, however, it should look like this:
        Calendar,WeekStarting,GreenBin,Garbage,Recycling,YardWaste,ChristmasTree
        Custom,03/07/18,1,0,1,0,0
        Custom,03/14/18,1,1,1,0,0
        Custom,03/21/18,1,0,1,0,0
        Custom,03/28/18,1,1,1,0,0
        And then there is the error message (see above).
        I have the version 2.18 of the MM running under Bullseye.
        M J 2 Replies Last reply Reply Quote 0
          MyMirror @MyMirror
          @all
          Who can help?
          I think the problem is here:
          ! There was an uncaught exception…
          0|mm | [07.02.2022 06:05.57.264] [ERROR] TypeError: parse is not a function
          0|mm | at /home/pi/MagicMirror/modules/MMM-MyWastePickup/node_helper.js:36:9
          Jens
            JohndB @MyMirror
            @mymirror
            correct without “Custom” in the beginning of each line.
            My first lines;
              MyMirror @JohndB
              @johndb
              Did not work on my site:
              Just shows “Loading …”
              My modules/MMM-MyWastePickup/schedule_custom.csv :
              02/09/22,0,1,0,0,0
              02/10/22,0,0,1,0,0
              03/02/22,0,1,0,0,0
              03/09/22,0,1,0,0,0
              03/10/22,1,0,0,0,0
              But on github (https://github.com/jclarke0000/MMM-MyWastePickup) is following:
              Using Your Own Custom Schedule
              If you live outside of Toronto and you’d like to use this module, you can create your own schedule to use with this module.
              First, in your config specify collectionCalendar: ‘Custom’.
              Create a CSV based on the following template:
              Add lines for each pickup date as needed
              I did so before Bullseye and everything was fine.
              Now with Bullseye, MM 2.18 and new node, npm i have a problem.
              Ideas?
                mr_cd @MyMirror
                @mymirror have you already found a solution?
                  sdetweil @mr_cd
                  @mr_cd can u show the config section from config.js?
                  the code checks
                  this.config.collectionCalendar
                    this.scheduleCSVFile = this.path + "/schedule.csv";
                      this.scheduleCustomCSVFile = this.path + "/schedule_custom.csv";
                  if not found it sets to look for
                  var scheduleFile = this.scheduleCSVFile;
                        if (payload.collectionCalendar == "Custom") {
                          scheduleFile = this.scheduleCustomCSVFile;
                  if you don’t have the collectionCalendar set
                  then it will use “schedule.csv”;
                    MyMirror @mr_cd
                    @mr_cd
                    Not really. I took another module for now. Here I have no foliage or Christmas trees, but until that applies, it still takes a little.
                                            module: 'MMM-MyGarbage',
                                            position: 'top_left',
                                            header: 'Müllabfuhr',
                                                    alert: 4,
                                                    weeksToDisplay: 2,
                                                    limitTo: 99,
                                                    fade: true,
                                                    dateFormat: "dddd D MMMM",
                                                    fadePoint: 0.25
