    npm start doesn't do anything but logs random words.
    9 Posts 3 Posters 1.9k Views 3 Watching
    • I Offline
      Ichiritzu
      Now, I am not exactly sure if I downloaded Jessie on my sd card. But that might be the problem?
      I followed everything on this website to step 6: https://www.magicmirrorcentral.com/complete-raspberry-pi-magic-mirror-tutorial/
      And when I do npm start, I get just a bunch of words in a log.
      [09.01.2022 18:47.24.988] [LOG]   undefined
      [09.01.2022 18:47.25.008] [LOG]   undefined
      [09.01.2022 18:47.25.013] [LOG]   undefined
      [09.01.2022 18:47.25.017] [LOG]                                      !             H|H|H|H|H           H__________________________________             H|§|§|§|H           H|* * * * * *|---------------------|             H|§|∞|§|H           H| * * * * * |---------------------|             H|§|§|§|H           H|* * * * * *|---------------------|             H|H|H|H|H           H| * * * * * |---------------------|             H|H|H|H|H           H|---------------------------------|          ===============        H|---------------------------------|            /| _   _ |          H|---------------------------------|            (| O   O |)          H|---------------------------------|            /|   U   |          H-----------------------------------             |  =/  |           H              _..._/            H              _|I/|_            H      _______/| H |/_______    H     /           / /          H    |          | | /         |  H    |          ||o||          |  H    |    |     ||o||     |    |  H    |    |     ||o||     |    |  H   Carl Pilcher
      I have no clue what’s going on.
      Edit: I also can’t post the full log because it’ll get flagged as spam.
        sdetweil @Ichiritzu
        @ichiritzu don’t do Jessie or stretch
        …use the latest, bullseye
        and then use my install script
        see
        • I Offline
          Ichiritzu @sdetweil
          @sdetweil said in npm start doesn't do anything but logs random words.:
          bullseye
          do I update the software or just reflash my sd?
            sdetweil @Ichiritzu
            @ichiritzu reflash, then use my script. don’t do anything else before that
            • I Offline
              Ichiritzu @sdetweil
              @sdetweil Ok, I reflashed and got Bullseye. Then I immediately followed your script and the same results. After installing nothing happens, it just instructs me to cd to MagicMirror and use pm2 start MagicMirror.
              When I do that, still nothing happens. It says status online, cpu 0%, and memory 2.8mb. Also when I do npm start, all it does is log random words like before.
                sdetweil @Ichiritzu
                @ichiritzu someone on discord is reporting similar issues…
                he said renaming mm folder and doing manual install
                git clone && npm install worked.
                not sure what is going on
                karsten13K 2 Replies Last reply Reply Quote 0
                • karsten13K Offline
                  karsten13 @sdetweil
                  see https://www.bleepingcomputer.com/news/security/dev-corrupts-npm-libs-colors-and-faker-breaking-thousands-of-apps/
                    karsten13 @sdetweil
                    it seems to be solved now, npm delivers now colors v1.4.0 as max version …
                    • I Offline
                      Ichiritzu @karsten13
                      @karsten13 @sdetweil
                      Awesome! thank y’all. I finally fixed by renaming the folder, changing the dependency ‘colors’ to 1.4.0 (removed the carrot), delete node_modles, and npm install.
