    Trying to update node.js fails
    26 Posts 3 Posters 10.1k Views 3 Watching
    • T Offline
      thad
      I recently updated MM and I’m having problems getting MM to start. It appears my issues are due to an old version of node.js (v10.15.2) and attempts to upgrade it fail. I can get MM to start using run-start.sh, but it doesn’t work with pm2. Here’s what I think should be a clue:
      Check current Node installation …
      Node currently installed. Checking version number.
      Minimum Node version: v16.9.1
      Installed Node version: v10.15.2
      Node should be upgraded.
      Installing Node.js …
      E: Repository ‘http://archive.raspberrypi.org/debian buster InRelease’ changed its ‘Suite’ value from ‘testing’ to ‘oldstable’
      E: Repository ‘http://raspbian.raspberrypi.org/raspbian buster InRelease’ changed its ‘Suite’ value from ‘stable’ to ‘oldstable’
      Reading package lists… Done
      Building dependency tree
      Reading state information… Done
      nodejs is already the newest version (10.15.2~dfsg-2+rpi1).
      0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      node version is
      Node.js installation Done! version=v10.15.2
      Check current NPM installation …
      NPM currently installed. Checking version number.
      npm does not support Node.js v10.15.2
      You should probably upgrade to a newer version of node as we
      can’t make any promises that npm will work with this version.
      You can find the latest version at https://nodejs.org/
      /usr/local/lib/node_modules/npm/lib/npm.js:32
      I need some help deciphering why it’s failing and what I can do to upgrade node.js successfully.
      Let me know if you have any suggestions, or if you think I’m looking in the wrong direction.
      Thanks.
      Thad
        sdetweil @thad
        @thad do you have nvm installed
        do
        which nvm
        (if nvm is NOT installed u will get a blank response)
        nvm sets its own path which overrides the base path
          sdetweil @thad
          @thad as for pm2, then show the pm2 logs
          pm2 logs --lines=100
          (ctrl-c to end)
          maybe need to clear them first to get shorter version
          pm2 flush
          then pm2 start
          them pm2 logs --lines=100 as above
          bugsounetB T 2 Replies Last reply Reply Quote 0
          • bugsounetB Offline
            bugsounet Banned @sdetweil
            @thad said in Trying to update node.js fails:
            @sdetweil : to correct this:
            sudo apt-get --allow-releaseinfo-change update
            (I’m really so kind, this cannot last !!! :dizzy_face: )
            T S 2 Replies Last reply Reply Quote 0
            • T Offline
              thad @sdetweil
              I don’t have nvm installed. The command ‘which nvm’ command returned nothing.
              If I clear the pm2 logs and immediately look at them, I’m seeing something odd. It appears I have 2 processed controlled by pm2. Here’s the output:
              pi@raspberrypi:~/MagicMirror $ pm2 logs --lines=100
              [TAILING] Tailing last 100 lines for [all] processes (change the value with --lines option)
              /home/pi/.pm2/pm2.log last 100 lines:
              /home/pi/.pm2/logs/MagicMirror-out.log last 100 lines:
              /home/pi/.pm2/logs/MagicMirror-error.log last 100 lines:
              /home/pi/.pm2/logs/mm-out.log last 100 lines:
              /home/pi/.pm2/logs/mm-error.log last 100 lines:
              I think the MagicMirror references are to my initial installation from a year or two ago. The references to ‘mm’ are what I attempted to do this morning.
              • T Offline
                thad @bugsounet
                @bugsounet said in Trying to update node.js fails:
                That made a big difference! The script that updates node.js now runs properly! Thanks.
                I’ll keep playing and see if I can get this thing running again.
                • T Offline
                  thad
                  @bugsounet @bugsounet
                  Thanks for your help. This has me running again. I need to work on the weather module some more. I have the current weather working, but the forecast is hung on ‘loading’. Thanks again for the super quick responses!
                    sdetweil @bugsounet
                    @bugsounet thx… added to upgrade, had for install
                      sdetweil @thad
                      @thad pm2 status shows the processes registered to manage
                      pm2 info x (x is name or number) will show what it run
                      pm2 delete x will remove an entry
                      pm2 --help will show all the things u can do .
                      • T Offline
                        thad @sdetweil
                        Thanks. I was able to remove the entry I created this morning, to there’s only one. I’m still having issues with pm2. If I start MM using pm2 after a couple of minutes it restarts. The pm2 log shows:
                        PM2 | pm2 has been killed by signal, dumping process list before exit…
                        PM2 | Deleting process 0
                        PM2 | Stopping app:MagicMirror id:0
                        PM2 | App [MagicMirror:0] exited with code [0] via signal [SIGTERM]
                        0|MagicMirror | /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGTERM
                        PM2 | pid=1386 msg=process killed
                        PM2 | Exited peacefully
                        0|MagicM
                        For some reason this keeps cycling. At the moment I’ve started MM using the run-start.sh script and it appears to be stable.
                          sdetweil @thad
                          @thad is there a cron job running? maybe killing pm2
                          • T Offline
                            thad @sdetweil
                            I don’t have any cron jobs running. A crontab -l says there’s nothing for user pi.
                              sdetweil @thad
                              @thad ok, lets see if we can start over on pm2
                              do
                              pm2 unstartup
                              it will give u a command to issue to remove the pm2 hooks
                              then do
                              sudo npm uninstall pm2
                              then run my fixuppm2.sh script again … it will redo all the setup
                              • T Offline
                                thad @sdetweil
                                Looks promising! MagicMirror has been running with the same pid for 5 minutes now!
                                • T Offline
                                  thad
                                  That worked for around 20 minutes and now it’s restarting randomly again. Let me get the pm2 logs…
                                  Here they are:
                                  0|MagicMirror | Newsfeed-Fetcher: Broadcasting 54 items.
                                  0|MagicMirror | [12.01.2022 11:40.16.970] [INFO]
                                  0|MagicMirror | Calendar-Fetcher: Broadcasting 9 events.
                                  0|MagicMirror | [12.01.2022 11:41.34.434] [LOG] Shutting down server…
                                  0|MagicMirror | [12.01.2022 11:41.34.457] [LOG] Stopping module helper: updatenotification
                                  0|MagicMirror | [12.01.2022 11:41.34.459] [LOG] Stopping module helper: MMM-AVStock
                                  0|MagicMirror | [12.01.2022 11:41.34.460] [LOG] Stopping module helper: calendar
                                  0|MagicMirror | [12.01.2022 11:41.34.461] [LOG] Stopping module helper: newsfeed
                                  0|MagicMirror | [1561:0112/114134.512661:ERROR:command_buffer_proxy_impl.cc(328)] GPU state invalid after WaitForGetOffsetInRange.
                                  0|MagicMirror | [1561:0112/114134.561597:ERROR:zygote_communication_linux.cc(276)] Failed to send GetTerminationStatus message to zygote
                                  0|MagicMirror | [1561:0112/114134.568770:ERROR:zygote_communication_linux.cc(276)] Failed to send GetTerminationStatus message to zygote
                                  PM2 | pid=1533 msg=process killed
                                  0|MagicMirror | > magicmirror@2.18.0 start
                                  0|MagicMirror | > DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
                                  0|MagicMirror | [12.01.2022 11:41.39.771] [LOG]
                                  0|MagicMirror | Starting MagicMirror: v2.18.0
                                    sdetweil @thad
                                    @thad fun times
                                    edit package.json and add
                                    --disable-gpu
                                    between the node_modules/electron and the js/electron.js
                                    on the start statement
                                    on my phone so hard to build good statement result… like this…
                                    "start":"DISPLAY=${DISPLAY:=:0}./node_modules/.bin/electron --disable-gpu js/electron.js"
                                    • T Offline
                                      thad @sdetweil
                                      Looking good. Right at an hour with no restarts.
                                        sdetweil @thad
                                        @thad what pi is this? and what os?
                                        lsb_release -a
                                        will show the os release info
                                        • T Offline
                                          thad @sdetweil
                                          It’s a pi4 running Raspbian release 10.
                                            sdetweil @thad
                                            @thad release 10, is that buster or bullseye?
                                            pi4, 2,4,8 gig?
